- Release notes Public Sector
- Getting Started
- Permissions
- Starting as
- Admin Console
- Workspace
- Explore
- Share Idea or Automation
- Dashboards
- My Tasks
- Notifications
- Email Notifications
- Resources
- Studio Integration
- Linking a Project to an Idea in Automation Hub
- Automation Hub Policy in Automation Ops
- Task Capture Integration
- Automation Store
- Additional Resources
Automation Hub User Guide for Public Sector
Before creating a new policy, make sure you're using the latest policy versions for applications. Do this by following the steps below:
In Automation Ops > Gouvernance, select Settings.
Select a 22.10 or higher version for Studioor StudioX and select Save.
To add a new product policy, follow the steps below:
In Automation Ops > Governance, select Add Product Policy.
Select Studio or StudioX, input a Name to your policy, and select Add.
Note: If you want to enforce the analyzer, activate the Enforce Analyzer before Publish setting in the Designsection. -
Select Workflow Analyzer tab and scroll down until you find the ST-USG-034 Rule ID.
- Select the Editicon.
Check the Is enabled box to activate the rule and select Save.
- In Automation Ops > Governance, select Deployment.
In the Users tab, select the Editicon beside your User Name.
Make sure that for the Studio, the newly created policy is selected.
Tip: To learn more about governance deployment check Deploy Governance Policies article.Note: If you can't find your user in the list, select Deployment for User, to create one.
Below is a video representation of the process:
