Automation Hub
- Release Notes
- Getting Started
- Permissions
- Starting as
- Admin Console
- Workspace
- Explore
- Share Idea or Automation
- Dashboards
- My Tasks
- Notifications
- Email Notifications
- Resources
- Process Mining Integration
- Studio Integration
- Task Capture Integration
- Automation Hub - Automation Cloud Integration
- Automation Store
- Additional Resources
Automation Hub - Assisted Task Mining Integration
Automation Hub User Guide
Last updated Apr 30, 2024
This feature empowers you to create a UiPath Assisted Task Mining project directly from the UiPath Automation Hub interface. This integration streamlines the process of initiating task mining projects, allowing you to seamlessly transition from identifying automation opportunities to collecting and analyzing user behavior data.
To enable the integration, you must meet the following prerequisites::
- In Automation Cloud you need to be an Organization Admin - to manage tenant level services and add the service if it isn't there.
- In Automation Hub you need to have the Manage the Tenant Settings permission to enable/disable the integration.
Note: The integration might be enabled by default. The following are the default statuses for the integration:
- Existing tenants with Automtion Hub and Task Mining - integration on by default.
- Existing tenants with Automation Hub and no Task Mining - integration is turned on when Task Mining is enabled.
- Existing tenants with only Task Mining - integration is turned on when Automation Hub is enabled.
- New tenants with Automation Hub and Task Mining - integration on by default.
- New tenants and existing tenant without Task Mining or Automation Hub - integration on by default.
