Automation Hub
- Release Notes
- Getting Started
- Permissions
- Starting as
- Admin Console
- Workspace
- Explore
- Share Idea or Automation
- Dashboards
- My Tasks
- Notifications
- Email Notifications
- Resources
- Process Mining Integration
- Studio Integration
- Task Capture Integration
- Automation Hub - Automation Cloud Integration
- Automation Store
- Additional Resources
Starting as a Business Reviewer
Automation Hub User Guide
Last updated Apr 30, 2024
After successfully logging in, you, as a Business Reviewer need to focus on pushing forward automations created by Citizen Developer Self Users and select the ones worth being endorsed for a Technical Review. To do this check the Automation Pipeline > Review page and review automations that are awaiting the business review.
- explore the list of submitted for your tenant and get inspired.
- check out and download the components submitted within your tenant.
