- Overview
- Data security and compliance
- Organizations
- Tenants
- Licensing
- Accounts and roles
- External applications
- Logging
Managing organization settings
Organization settings are broadly-applicable and impact everyone who uses Automation Cloud™. Settings can impact all tenants, all services, and all users, except where options exist to customize more granularly.
If you are an organization administrator, you can access the Admin space, which include the organization settings.
To access organization settings
From the App launcher (top left corner), select Admin. You are then redirected to the organization settings page.
If you are already browsing the Admin pages, click your organization name at the top of the panel on the left:
Account Logical Name
) greatly impacts the entities that used the previous URL.
- Robots configured at the services level are disconnected. If you change the URL, you need to reconnect your Robots, entering the new URL.
- Bookmarks containing the organization URL don't work anymore. You must send the new URL to your users.
- User invites that were sent before the URL change are no longer valid. You must send new invites for the colleagues who haven’t joined yet.
- Mobile Orchestrator users are disconnected. Send them the new URL to connect again.
You can personalize Automation Cloud to also display your own company logo in the header:
To add your logo
The appropriate logo for your current theme appears in the header.
The Support ID uniquely identifies your organization. You must provide this ID if you want to:
- contact sales to request an upgrade to the Enterprise plan.
- contact support (only available for Enterprise; for other plans, use the UiPath® Community Forum).
To view your Support ID, go to Admin, select your organization, and then select Settings. The Settings page for the organization opens and the Support ID is shown in the top-right of the page.
Alternatively, click the Help button on the header. The Help menu opens and the Support ID is shown first in the menu.
For Community and Free plan users, this feature is not available.
For organization-wide services, you can choose to hide the left rail navigation icons from all non-administrator users in your organization. Users can still access the service if they have the direct URL to the service, this change only removes the navigation icon.
To hide unused services:
Hidden items are no longer visible in navigation for your users, only organization administrators can continue to see them. Shown items are visible in navigation to all users.
User license management allows you to get more out of user licenses because one license can be used across all tenants. When this setting is disabled, user licenses are bound to the tenant to which they are allocated.
For more information about this option, see User license management.
Only enable user license management if:
- you are not using classic folders
- your organization is using or can switch to using interactive authentication.
Enabling user license management automatically sets the Enforce user authentication, disable robot key authentication security setting in Orchestrator. Any users who use robot key authentication can no longer connect their robots to Orchestrator until they switch to interactive authentication. This setting is incompatible with classic folders.
Important: If you are now switching to secure authentication, this requires recompiling the workflows that use Orchestrator activities or make direct HTTP calls to the Orchestrator API utilizing 2020.10 activity packages or later.
If user licensing was enabled for your organization, but you do not find it valuable, you can switch back to the legacy licensing model.
Step no. |
What | Where |
1 |
Disable user licensing. |
Automation Cloud > Admin > Organization > Settings > Advanced > User License Management |
2 |
Recreate your previous allocation schema, by re-allocating user licenses to each tenant. |
Automation Cloud > Admin > Tenant > Licenses > Edit allocation |
3 |
Disable the user authentication enforcement if you were not using interactive authentication before enabling user license management. |
Orchestrator > Tenant > Settings > Security > Enforce user authentication, disable robot key authentication. |
System email notifications help keep your organization informed about important events and updates. When it comes to email configuration, administrators can choose between custom mail settings or default settings provided by UiPath. You can change email settings from Admin, the Mail settings tab.
Notifications can be related to user accounts (password recovery), or be related to events from services such as Orchestrator.
- Go to Admin, select your organization, and then select Settings. The Settings page for the organization opens.
- Along the top, select the Email tab. The SMTP Options page opens.
- Select the Use default mail settings checkbox. The default SMTP settings are described on the page.
- If you are satisfied with using the default settings, click Save to apply changes. This will apply the default UiPath configuration to all emails sent within the context of the organization.
Default email settings
The default mail settings use the SendGrid SMTP server with the following settings:
Setting |
Description |
Value |
Sender address | The email address that is used as the source of the emails being sent. It represents the identity of the sender and is displayed in the recipient's inbox as the address from which the email originated. |
admin@mydomain.com |
Sender name | The human-readable name associated with the sender's email address. It appears alongside the sender's email address in the recipient's inbox. |
mydomain.com mailer |
- Select the Use custom mail settings checkbox.
- Configure the custom email settings, by providing the neccessary information for your SMTP configuration.
- After entering the SMTP details, click Test mail settings to validate your settings. The Test mail settings page opens.
- Add an email address for sending the test email, and click Send. This will send a test email to a designated email address to ensure that your configuration is correct and functioning as expected. Make sure to check your inbox for the test email.
- Once the test email is successfully sent and received, click Save to save the SMTP settings. This will apply the custom configuration to all emails sent within the context of the organization.
Custom email settings
To configure custom email settings for your own SMTP server, provide the necessary information for your SMTP configuration.
Setting |
Description |
Example |
Hostname | The SMTP server that handles the sending of your emails. |
Smtp.office.com |
Domain | The email server responsible for handling emails. |
Provider.com |
Port | The communication port used for sending emails. Port 25 is commonly used, but some email providers also offer ports like 587. |
25 |
Timeout | Maximum duration that the system waits for a response from the SMTP server. If the server does not respond within the specified timeout period, the attempt is considered unsuccessful. |
180,000 ms |
Use TLS encryption | When enabled, it ensures that sensitive data remains confidential during transit. |
N/A |
Require authentication |
When enabled, you should provide valid credentials (username and password) before the system is allowed to send emails through the SMTP server. |
Username: name@name.com Password: ******** |
If you have duplicate organizations, you are moving from cloud to on-premises, or you just decided that you want to stop using Automation Cloud, as an organization administrator you have the option to explicitly delete the data for an organization.
If you want to delete your Automation Cloud organization and its data, please open a Support ticket to request that we delete your organization for you.
- Accessing organization settings
- Changing the organization name or URL
- Changing the URL
- Adding your company logo
- Finding your support ID
- Hiding unused services
- Changing the license management option
- Enabling user license management
- Disabling user license management
- Configuring system email notifications
- Using default email settings
- Using custom email settings
- Deleting your organization
- Deleting organizations
