Automation Cloud Public Sector
Banner background image
Automation Cloud for Public Sector Admin Guide
Last updated May 9, 2024
About licensing
The following information is aimed at helping you understand how UiPath® licenses its software. You can think of a license as an agreement between you and UiPath, authorizing you to use a certain set of functional capabilities in UiPath software.
Note:
Our commercial offering provides a flexible variety of licensing SKUs for how to deploy and use UiPath software.
See the UiPath Licensing page for the current list of available SKUs. For Automation CloudTM Public Sector, the applicable SKUs are on the Flex Plan tab.
Licensing plan framework
You can use Automation Cloud with a licensing plan to match your automation needs and budget.
Enterprise
The Enterprise plan is a yearly plan which includes custom license types and license counts, tailored to your specific needs with help from our Sales team. To get started, you must contact Sales.
You can purchase as many licenses of each type as you want, and you gain access to the full stack of premium plan perks that are included with this plan.
You can also purchase products in bundles, called Platform SKUs. These are currently available under the form of two tiers, namely Standard and Advanced. The capabilites included in each tier differ, and are detailed on the UiPath Licensing page.
Plan breakdown
The following benefits are available for Automation CloudTM Public Sector:
Plan perks
Enterprise
Max. tenants 1
As needed
Max. user accounts
As needed
Access to UiPath Support
Standard Support; can be upgraded to Premium Support
Yes
USER LICENSES
Attended - Named User
As purchased
Citizen Developer - Named User
As purchased
Automation Developer - Named User
As purchased
Action Center - Named User
As purchased
Tester - Named User
As purchased
Insights Designer - Named User
As purchased
Process Mining Developer User
As purchased, or service trial available
Process Mining Business User
Assisted Task Mining
Included
ROBOT LICENSES (RUNTIMES)
Unattended Robot
As purchased
NonProduction Robot
As purchased
Testing Robot
As purchased
SERVICE LICENSES
As purchased (only available in the Advanced tier)
Test Management
As purchased
Automation Hub
As purchased, or
Service trial available
Insights
As purchased, or
Apps
Included
Action Center
Included
Data Service
1 unit included for each purchased user or robot license
Can be supplemented with additional licenses purchased
Each unit grants 1 GB of data storage, 5 GB of attachment storage and 10,000 API calls/day.
Document Understanding 3
Included with purchased AI Units
Computer Vision
240 megapixels/min
1 Each tenant comes with one Orchestrator service.
2 AI units are used to license several of our AI products.
Robot units fallback
Organization administrators can choose to enable a fallback mechanism for scenarios where robot units run out. Specifically, if you use Studio Web and you deplete your allocated robot units for running personal automations, you can be assigned extra robot units from the tenant pool.
To do that, the License fallback option in the Edit license allocation window must be enabled.
About license types
User licenses
To learn more about user licenses, see:
  • User licensing for general information
  • The documentation of each product for details about a user license that is specific to that particular product
Service licenses
To learn more about these types of licenses, see Service licensing.
  • Licensing plan framework
  • Enterprise
  • Plan breakdown
  • About license types
  • User licenses
  • Service licenses
