Automation Suite
- Overview
- Requirements
- Prerequisite checks
- uipathctl cluster
- uipathctl cluster migration
- uipathctl cluster upgrade
- uipathctl config
- uipathctl config alerts
- uipathctl config argocd
- uipathctl health
- uipathctl health bundle
- uipathctl health check
- uipathctl health diagnose
- uipathctl health test
- uipathctl manifest
- uipathctl manifest apply
- uipathctl manifest diff
- uipathctl manifest get
- uipathctl manifest render
- uipathctl prereq
- uipathctl prereq create
- uipathctl prereq run
- uipathctl resource
- uipathctl resource report
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- uipathctl version
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Monitoring and alerting
- Cluster administration
- Troubleshooting
Migration steps
Automation Suite on EKS/AKS Installation Guide
Last updated May 20, 2024
Migration steps
To start the migration operation, take the following steps:
Move the Identity organization data from standalone to Automation Suite. Details...
Restore the standalone product database. Details...
Back up the platform database in Automation Suite. Details...
Merge the organizations in Automation Suite. Details...
Update the migrated product connection strings.
Migrate standalone Orchestrator. Details...
Migrate standalone Insights. Details...
Delete the default tenant. Details...
