Automation Suite
- Overview
- Requirements
- Prerequisite checks
- uipathctl cluster
- uipathctl cluster migration
- uipathctl cluster upgrade
- uipathctl config
- uipathctl config alerts
- uipathctl config argocd
- uipathctl health
- uipathctl health bundle
- uipathctl health check
- uipathctl health diagnose
- uipathctl health test
- uipathctl manifest
- uipathctl manifest apply
- uipathctl manifest diff
- uipathctl manifest get
- uipathctl manifest render
- uipathctl prereq
- uipathctl prereq create
- uipathctl prereq run
- uipathctl resource
- uipathctl resource report
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- uipathctl version
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Monitoring and alerting
- Cluster administration
- Troubleshooting
Using the Orchestrator Configurator Tool
Automation Suite on EKS/AKS Installation Guide
Last updated May 20, 2024
The Orchestrator Configurator Tool is a bash script designed to facilitate the placement of files and settings within the
Orchestrator deployment in Automation Suite. It assists in adding storage files, credential store plugins, NLog extensions,
new NLog configuration, and overriding
appSettings
Examples of operations that can be performed using this tool include:
The environment where you use the Orchestrator Configurator Tool must be capable of running a bash script and should have the following tools:
- kubectl configured with a connection to the cluster
- jq 1.6
- rclone (installation steps)
Important:
Do not download and use the ArgoCD CLI tool independently. To maintain compatibility and ensure smooth operation, we recommend using the ArgoCD we bundle within the Automation Suite artifacts. To do that, you must add ArgoCD to your path from the latest installer by running the following command:
export PATH=$PATH:/opt/UiPathAutomationSuite/<version>/installer/bin
To be able to run Orchestrator Configurator Tool from any location, update the
PATH
variable to include <installer-dir>/Tools
, as shown in the following example:
export PATH="$PATH:/opt/UiPathAutomationSuite/online_installer_<version>/Tools"
Make sure that the version of the
jq
utility is 1.6. If it is not, update it using one of the following options:
Option 1:
yum install -y epel-release yum install -y jq
yum install -y epel-release yum install -y jq -
Option 2:
curl https://download-ib01.fedoraproject.org/pub/epel/7/x86_64/Packages/j/jq-1.6-2.el7.x86_64.rpm --output /tmp/jq-1.6-2.el7.x86_64.rpm yum localinstall /tmp/jq-1.6-2.el7.x86_64.rpm jq --version
Usage: ./orchestrator_configurator.sh \
-s blobstoragefolder -p pluginsfolder -n nlogextensionsfolder \
-c appsettings.custom.config -l nlog.custom.config
-k|--encryption-key
the value of the encryption key that will override the key generated at install
-c|--app-settings
application configuration file containing json with key-value structure
-l|--nlog-config-file
nlog config file, json
-s|--storage-folder
location of the storage folder on the local disk
-n|--nlog-extensions-folder
location of the nlog extensions on the local disk
-p|--securestore-plugins-folder
location of the securestore plugins on the local disk
--use-external-storage
use external storage instead of in cluster CEPH storage
-d|--dry-run
do not update the orchestrator app with the new values
-y|--accept-all
do not prompt for confirmation of actions and overwriting of files with kubectl cp.
-k|--encryption-key
-c|--app-settings
-s|--storage-folder
-d|--dry-run
-y|--accept-all
