test-manager
  • Getting started
    • About this guide
    • About installation
  • Hardware and software requirements
  • Installation and upgrade
Test Manager installation guide
Last updated Oct 27, 2025
Troubleshooting
If you run into installation or upgrade issues, consider the following troubleshooting scenarios:
The following Windows features need to be enabled in Windows settings
You might run into this installation error if you have missing IIS modules.
To solve this issue, make sure that you have installed all the IIS modules. For more information, see Software Requirements and Prerequisites.
You don't have the necessary rights to access this application
Important:
Make sure that you have allocated a Testing Runtime license at the tenant level.
If you have previously logged in using the host tenant, you need to change it to Default.
  1. You get the following message if the tenant is set to host.
  2. Click the logout button.
  3. Go to Change to specify the tenant.
  4. In the Tenant Name enter Default as your tenant.
  5. Enter your credentials and click Log in.
The Following Windows Features Need to Be Enabled in Windows Settings
You Don't Have the Necessary Rights to Access This Application
Important:
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
