test-suite
The Test Suite guide has been deprecated. For the latest documentation on Test Manager and UiPath testing capabilities, visit the Test Manager guide.
DEPRECATED
Test Suite User Guide
Last updated Sep 18, 2025
Xray for Jira
The Xray Test Management for Jira integration provides an alternative to managing your tests using the Test Manager. To take advantage of this, you need to install the Jira connector and complete the integration by configuring a new connection in the Test Manager.
To connect your Test Manager instance to an XRay project follow these procedures:
Supported object types and data transfer direction
Supported objects
  • Items synchronized from Xray for Jira to Test Manager are read-only except for attachments, object labels and test case links.
  • Defects are synchronized from test executions in Test Manager to Xray for Jira.
Data transfer
The direction of data transfer and corresponding objects are listed in the following table:
Xray for Jira
Direction
UiPath Test Manager
Requirements
Requirements
Test cases
Test cases
Defect
Defects
Prerequisites
Install UiPath® Test Manager for Jira
  1. Log in to Jira as an administrator.
  2. Navigate to Settings > Manage Apps.
  3. Go to Find new apps.
  4. Use the search bar to find UiPath® Test Manager for Jira.
  5. Click Install to add the app to Jira.
Configure Xray Connection
  1. Log in to Test Manager as an administrator.
  2. Open your project.
  3. Navigate to Project Settings > Integration.
  4. Click New Connection and select XRay from the dropdown to edit the connection.
  5. Configure as follows:
    • Name: Enter a name for your Xray project.
    • Description (optional): Add a description.
    • Server URL: Add the Jira Server URL, including the port number. This is the URL of the server that exposes the Jira REST API. It is usually identical to the URL you navigate to when using Jira through your browser. For example: https://company-name.atlassian.net.
    • Web URL (optional): Add the web URL in case the server URL is not hosted under the same address as the web URL used to access Jira resources.
    • Username: The username you use to authenticate to the Jira API.
    • Password (Xray Server only): The password you use to authenticate to the Jira API.
    • Project Key: Enter the project key from Jira which refers to the project you want to integrate.
    • API Token (Xray Cloud only): Generate an API token. For more information on Atlassian API tokens, see Manage API tokens for your Atlassian account.
    • Client Id (Xray Cloud only): Create an API Key containing a Client Id and Client Secret. You need to be a Jira administrator to perform this action. Enter the Client Id generated in Jira Software.
    • Client Secret (Xray Cloud only): Enter the Client Secret generated in Jira Software.
  6. Click Save to add the connection. The Xray connection is added to the Integration list.
  7. Copy the API Key.
  8. Open Jira and navigate to Project Settings > UiPath® Test Manager.
  9. Configure project settings and paste the API key in the API Key - XRay Integration field.
Editing an Xray Connection
  1. Log in to the Test Manager as an administrator.
  3. Click the Settings button to open Project Settings.
  4. In the Integration list, click an Xray connection to expand the panel.
  5. Click Edit to configure the connection.
  6. Click Save to confirm.
Deleting an Xray Connection
Deleting the connection removes all associated requirements and test cases.
  5. Click Delete to remove the connection.
  6. Click Ok to confirm.
Managing Tests Via Xray
The tests executed through the Orchestrator propagate the results to Xray. For more information on managing tests using Xray, see the Xray Documentation Home.
Important:
  • Test cases edited in the Test Manager are not synchronized with Xray. Conversely, changes made to test cases in Xray are reflected in the Test Manager.
Related articles
