- Premiers pas avec Test Cloud
- Gérer les organisations Test Cloud
- Utiliser Test Cloud
Guide de l'administrateur de Test Cloud
Test Suite has evolved into Test Cloud, UiPath's dedicated platform for modern application testing.
Test Cloud provides a focused, scalable environment designed specifically for application testers.
Here is what you get with Test Cloud that was not part of Test Suite:
| Capacité | Détails (Details) | En savoir plus |
| Test d'application | Test Cloud - a dedicated platform for application testers, supporting both application and RPA testing. | À propos de Test Cloud |
| RPA testing | Automation Cloud - RPA testing remains part of the broader automation platform. | Test dans votre organisation |
Test Suite served as an umbrella for both RPA and application testing. This dual purpose often made it unclear whether UiPath testing was part of the automation platform or a standalone offering for application testers.
To address this, UiPath introduced Test Cloud as a dedicated platform designed specifically for application testing. RPA testing capabilities remain part of Automation Cloud, where they naturally belong alongside the broader automation platform.
If you are currently using Test Suite under the Flex licensing plan and want to move to Test Cloud under the Unified Pricing plan, refer to Migrate from Test Suite to Test Cloud for planning guidance and high-level migration steps.
