test-cloud
  • Premiers pas avec Test Cloud
    • About UiPath Test Suite
    • À propos de Test Cloud
    • Services disponibles
    • Accessing Test Cloud Dedicated
    • Premiers pas avec la plate-forme
    • Exploration de l'interface utilisateur
    • Migrer de Test Suite vers Test Cloud
  • Gérer les organisations Test Cloud
  • Utiliser Test Cloud
Guide de l'administrateur de Test Cloud
Dernière mise à jour 25 mars 2026
This section provides key considerations and high-level steps for migrating from Test Suite under the Flex pricing plan to Test Cloud Dedicated under the Unified Pricing plan.
Pour plus d'informations sur la tarification, parcourez nos plans de tarification ou contactez votre point de contact.
Avantages de la migration vers Test Cloud
If you are unsure on whether to upgrade to Test Cloud Dedicated, here are some of the key benefits and considerations:
  • Test Cloud Dedicated is a dedicated cloud service focused on application testing. Test Cloud Dedicated extends the testing capabilities previously available in UiPath® Test Suite. Unlike UiPath Test Suite, which was part of broader automation offerings, Test Cloud is a cloud offering similar to Automation Cloud, but designed specifically for application testing.
    Historiquement, les fonctionnalités UiPath Test Suite étaient livrées dans le cadre d'Automation Cloud.Ces fonctionnalités couvraient à la fois les tests RPA et les tests d'applications.
  • All new application‑testing features will be released only in Test Cloud Dedicated, no longer in UiPath® Test Suite, regardless of the delivery option. Continuing to use the capabilities offered by UiPath® Test Suite means missing out on future innovations for application testing.
  • Test Cloud Dedicated is licensed exclusively under our new . In contrast, the capabilities offered by UiPath® Test Suite remain available only under the legacy Flex Pricing plan. This means upgrading to Test Cloud Dedicated ensures both technical and commercial alignment with the future of the UiPath platform.
  • If your IT team is concerned about security reviews for Test Cloud Dedicated, the good news is Test Cloud Dedicated is not a new tool entering your organization. The application runs on the same secure infrastructure as Automation Cloud. Think of Test Cloud Dedicated as a different user experience on top of the same secure foundation. In other words, there is no need for additional security reviews or approvals for Test Cloud Dedicated.
Démarrer le processus de migration
Si vous avez besoin d'aide pour démarrer votre processus de migration, nous avons ce qu'il vous faut. Voici ce que vous devez d'abord faire :
Contacter vos points de contact
Si vous disposez d'un gestionnaire de compte technique (TAM) UiPath® dédié, contactez-le d'abord pour planifier et exécuter votre migration. Si aucun TAM n'est affecté à votre compte, notre équipe de services professionnels peut intervenir pour diriger et exécuter la migration en votre nom.
En outre, notre équipe d'assistance peut vous aider à clarifier les étapes et à partager une liste de contrôle des activités et des outils requis, bien qu'elle n'effectue pas la migration elle-même.
Partager les informations initiales pour votre migration
Lorsque vous nous contactez au sujet de vos plans de migration, assurez-vous que vous disposez des informations suivantes. Cela nous aidera à comprendre votre contexte et à associer rapidement votre situation à l'approche de migration adéquate :
  • Où votre environnement actuel est-il hébergé ? : l'option de livraison que vous utilisez.
  • Dans quel but utilisez-vous actuellement UiPath : qu'il s'agisse de tests d'applications, de tests RPA/d'automatisation, ou à la fois de tests d'applications et de tests RPA/d'automatisation.
  • Where are these activities performed?: Let us know whether application testing and RPA/automation testing are managed within the same , or in separate organizations.
  • What activities are you planning to migrate?: Indicate whether it is just application testing to Test Cloud or you also want to upgrade RPA/automation testing capabilities to the .
Planification et évaluation
Pendant cette phase, votre objectif est de comprendre la configuration actuelle et de planifier l'étendue de la migration.
Conseil : certaines des étapes de haut niveau répertoriées ci-dessous vous permettront de démarrer correctement la migration.
  • Alignez les parties prenantes, définissez les objectifs et définissez les mesures de réussite.
  • Rassemblez des détails sur les ressources actuelles (packages, workflows, cas de test).
  • Clarifiez ce qui est en cours de migration : tests d'applications, tests RPA/automatisation ou les deux.
  • Examinez les rôles utilisateur, les autorisations d'accès et les besoins de gouvernance.
  • Élaborez une feuille de route de migration avec des tâches, des propriétaires et des échéanciers.
  • Identifiez les défis potentiels et décrivez la stratégie de migration.
Configuration de la préparation UiPath Cloud
This section highlights how to prepare the Test Cloud Dedicated environment for migration:
  • Configurer les locataires et la structure organisationnelle.
  • Configurez les rôles d'accès et les autorisations utilisateur selon les besoins.
  • Connectez Test Manager à des outils ALM, tels que Jira ou Azure DevOps.
  • Activez Test Manager et confirmez la disponibilité des licences.
  • Reproduisez les environnements et la structure de dossiers de la configuration actuelle.
  • Passez en revue l'affectation des licences et assurez-vous que l'enregistrement est terminé.
Migration des ressources et des packages
Next, move reusable components and packages to Test Cloud Dedicated:
  • Inventoriez les ressources telles que les files d'attente, les informations d'identification et les compartiments de stockage.
  • Identifiez les actifs obsolètes ou inutilisés à exclure de la migration.
  • Exportez des packages et des ressources depuis l'instance source d'Orchestrator.
  • Utilisez des outils de migration ou des étapes manuelles pour importer dans Test Cloud.
  • Validez les valeurs, les types et les références des ressources après la migration.
  • Republiez les packages dans l'environnement cible pour garantir la compatibilité.
Migration d'incidents et d'artefacts de test
Il s'agit de la partie où les cas de test et les artefacts Orchestrator connexes sont migrés :
  • Utilisez les fonctionnalités d'exportation et d'importation de projets pour transférer des projets Test Manager.
  • Reconfigurez les paramètres du projet après l'importation (par exemple, les intégrations ou les rôles).
  • Réorganisez les incidents de test dans la nouvelle structure si nécessaire.
  • Assurez-vous que les cas de test sont liés aux objets de test ALM, le cas échéant.
  • Validez les ensembles de tests et confirmez qu'ils peuvent s'exécuter avec succès.
  • Vérifiez que tous les artefacts requis sont disponibles dans l'environnement cible.
Configuration de l'environnement et connectivité
Ces étapes décrivent ce qui doit être fait pour garantir que les robots et les environnements de test fonctionnent comme prévu :
  • Déployez des robots de test non assistés dans le nouvel environnement.
  • Affectez des utilisateurs et des robots aux dossiers appropriés.
  • Validez l'accès aux machines de test via des ressources virtuelles ou locales.
  • Confirmez la connectivité réseau et testez l'accès à Credential.
  • Exécutez des exemples de workflows pour valider le comportement d'exécution du robot.
Validation et exécution de test
Ensuite, vous devez valider la migration via l'exécution de test :
  • Exécutez des tests de fumée pour valider le comportement global du système.
  • Comparez les résultats attendus et réels pour les tests migrés.
  • Corrigez les variables manquantes, les ressources ou les dépendances brisées.
  • Remappez les sources de données de test et les références d'environnement si nécessaire.
  • Documentez les résultats des tests et les preuves de validation dans les rapports.
  • Partagez le résumé des résultats et confirmez l'achèvement de la validation.
Intégration CI/CD
Si nécessaire, procédez comme suit pour intégrer l'automatisation de test dans votre pipeline.
  • Ajustez les intégrations CI/CD (par exemple, Jenkins ou Azure DevOps) en conséquence.
  • Configurez les pipelines pour déclencher les ensembles de test pendant les phases de déploiement.
  • Ajoutez des étapes de validation de test après le déploiement dans les pipelines CI/CD.
  • Assurez-vous que les résultats sont resynchronisés avec ALM ou les systèmes de suivi des défauts.
  • Fournissez des exemples de fichiers YAML ou de configuration à réutiliser.
Rapports et Insights de test
Les étapes ci-dessous expliquent comment créer des tableaux de bord et des outils de visibilité de test :
  • Définissez les besoins en matière de rapports tels que la couverture, le taux de réussite et les tendances.
  • Activez et configurez UiPath Insights ou d'autres solutions de rapports.
  • Créez des tableaux de bord pour visualiser l'activité de test et les résultats.
  • Planifiez la génération et la cadence de livraison de rapports automatisées.
  • Partagez régulièrement des tableaux de bord et des Insights avec les principales parties prenantes.
Transfert et documentation
Enfin, finalisez la migration et activez la propriété à long terme en finalisant la documentation, en terminant le transfert de connaissances et en transférant la propriété.
