orchestrator
Guide de l'API Orchestrator
Requêtes relatives aux paquets (Packages Requests)
Exemples de requêtes d'API pour interroger des packages et récupérer les détails de la version de processus via des points de terminaison OData.
Récupération de toutes les versions disponibles pour un paquet spécifique​
Obtenir
https://{yourDomain}/{organizationName}/{tenantName}/orchestrator_/odata/Processes/UiPath.Server.Configuration.OData.GetProcessVersions(processId='QueueItemsProcessing')
En-têtes de requête.​
Clé (Key)Valeur (Value)
AutorisationPorteur
Codes de réponse​
200 OK
Corps de la réponse​
  "@odata.context": "https://{yourDomain}/{organizationName}/{tenantName}/orchestrator_/odata/$metadata#Processes",
  "@odata.count": 2,
 "value": [
            "IsActive": true,
            "SupportsMultipleEntryPoints": false,
            "MainEntryPointPath": null,
            "RequiresUserInteraction": true,
            "TargetFramework": "Legacy",
            "Title": null,
            "Version": "1.0.6981.35861",
            "Key": "QueueItemsProcessing:1.0.6981.35861",
            "Description": "Process items from an Orchestrator queue.",
            "Published": "2021-07-23T16:40:07.793Z",
            "IsLatestVersion": false,
            "OldVersion": null,
            "ReleaseNotes": null,
            "Authors": "petrina.calota",
            "ProjectType": "Undefined",
            "Tags": null,
            "Id": "QueueItemsProcessing",
            "Arguments": {
                "Input": "[{\"name\":\"argument1\",\"type\":\"System.Int32, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089\",\"required\":false,\"hasDefault\":true},{\"name\":\"argument2\",\"type\":\"System.Int32, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089\",\"required\":false,\"hasDefault\":false},{\"name\":\"argument3\",\"type\":\"System.String, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089\",\"required\":false,\"hasDefault\":true}]",
                "Output": null
  "@odata.count": 2,
 "value": [
            "IsActive": true,
            "Title": null,
            "OldVersion": null,
            "Tags": null,
            "Arguments": {
                "Output": null
Téléchargement d'une version de paquet spécifique​
La requête ci-dessous vous permet de télécharger le package portant le nom « add_queue_items » et la version 1.0.6654.27080.
Obtenir
https://{yourDomain}/{organizationName}/{tenantName}/orchestrator_/odata/Processes/UiPath.Server.Configuration.OData.DownloadPackage(key='add_queue_items:1.0.6654.27080')
AutorisationPorteur
Codes de réponse​
200 OK
Récupération des arguments d'un paquet​
La requête GET suivante effectuée vers le point de terminaison /odata/Processes/UiPath.Server.Configuration.OData.GetArguments(key='key') renvoie tous les arguments d'entrée et de sortie d'un paquet spécifique, leur type et s'ils ont une valeur par défaut. Les arguments d'entrée; de sortie ou d'entrée/de sortie d'un projet deviennent les paramètres d'entrée et de sortie dans Orchestrator.
Obtenir
https://{yourDomain}/{organizationName}/{tenantName}/orchestrator_/odata/Processes/UiPath.Server.Configuration.OData.GetArguments(key='input_output_test%3A1.3.5')
AutorisationPorteur
Codes de réponse​
200 OK
    "@odata.context": "https://{yourDomain}/{organizationName}/{tenantName}/orchestrator_/odata/$metadata#UiPath.Core.Arguments.ArgumentMetadata",
    "Input": "[\r\n  {\r\n    \"name\": \"age\",\r\n    \"type\": \"System.Int32, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089\",\r\n    \"required\": false,\r\n    \"hasDefault\": false\r\n  },\r\n  {\r\n    \"name\": \"Array\",\r\n    \"type\": \"System.Int32[], mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089\",\r\n    \"required\": false,\r\n    \"hasDefault\": true\r\n  },\r\n  {\r\n    \"name\": \"trueOrFalse\",\r\n    \"type\": \"System.Boolean, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089\",\r\n    \"required\": false,\r\n    \"hasDefault\": true\r\n  },\r\n  {\r\n    \"name\": \"dateNow\",\r\n    \"type\": \"System.DateTime, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089\",\r\n    \"required\": false,\r\n    \"hasDefault\": true\r\n  },\r\n  {\r\n    \"name\": \"stringNew\",\r\n    \"type\": \"System.String, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089\",\r\n    \"required\": false,\r\n    \"hasDefault\": false\r\n  },\r\n  {\r\n    \"name\": \"arrayStrings\",\r\n    \"type\": \"System.String[], mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089\",\r\n    \"required\": false,\r\n    \"hasDefault\": false\r\n  },\r\n  {\r\n    \"name\": \"inOutTry\",\r\n    \"type\": \"System.Object, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089\",\r\n    \"required\": false,\r\n    \"hasDefault\": false\r\n  }\r\n]",
    "Output": "[\r\n  {\r\n    \"name\": \"output\",\r\n    \"type\": \"System.String, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089\"\r\n  },\r\n  {\r\n    \"name\": \"inOutTry\",\r\n    \"type\": \"System.Object, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089\"\r\n  }\r\n]"
Modifier des paramètres au niveau du package​
Il est possible de mettre à jour les paramètres d'entrée et de sortie d'un projet en effectuant une requête POST au point de terminaison /odata/Processes/UiPath.Server.Configuration.OData.SetArguments.
Remarque :
Cet appel remplace tous les paramètres précédents et offre la validation. En outre, notez que ce point de terminaison permet de modifier les paramètres d'entrée et de sortie d'un paquet d'automatisation uniquement si vous ne l'avez pas téléchargé dans Orchestrator via l'API, la page Paquets (Packages) ou le flux NuGet.
Pour mettre à jour uniquement les valeurs des paramètres d'entrée, vous pouvez le faire au niveau des processus, au niveau des tâches, et/ou au niveau des planifications.
Publier
https://{yourDomain}/{organizationName}/{tenantName}/orchestrator_/odata/Processes/UiPath.Server.Configuration.OData.SetArguments
AutorisationPorteur
Corps de la requête​
  "key": "input_output_test:1.3.6",
  "arguments": {
    "Input": "[{\"name\":\"arg1\", \"type\": \"System.String\", \"required\": false}]",
    "Output": "[{\"name\":\"outputArg\", \"type\":\"System.String\", \"required\":false}]"
  "arguments": {
Codes de réponse​
200 OK
Récupérer des packages​
Obtenir
AutorisationPorteur
Codes de réponse​
200 OK
  "@odata.count": 2,
    "value": [
            "IsActive": false,
            "Title": null,
            "Published": "2021-07-23T16:40:07.7933333Z",
            "OldVersion": null,
            "Tags": null,
            "Arguments": {
                "Output": null
  "@odata.count": 2,
    "value": [
            "IsActive": false,
            "Title": null,
            "OldVersion": null,
            "Tags": null,
            "Arguments": {
                "Output": null
