test-cloud
  • Primeros pasos con Test Cloud
    • Acerca de Test Cloud
    • About UiPath Test Suite
    • Servicios disponibles
    • Acceso a Test Cloud Sector público
    • Primeros pasos con la plataforma
    • Explorar la interfaz de usuario
    • Licencia
    • Migrar de Test Suite a Test Cloud
  • Gestión de organizaciones de Test Cloud
  • Trabajar con Test Cloud
Guía de administración de Test Cloud
Última actualización 25 de mar. de 2026
Test Suite has evolved into Test Cloud, UiPath's dedicated platform for modern application testing.
Test Cloud provides a focused, scalable environment designed specifically for application testers.
What you get with Test Cloud
Here is what you get with Test Cloud that was not part of Test Suite:
Tabla 1.
CapacidadDetallesMás información
Prueba de aplicaciónTest Cloud - a dedicated platform for application testers, supporting both application and RPA testing. Acerca de Test Cloud
RPA testingAutomation Cloud - RPA testing remains part of the broader automation platform. Pruebas en su organización
Why this change was made
Test Suite served as an umbrella for both RPA and application testing. This dual purpose often made it unclear whether UiPath testing was part of the automation platform or a standalone offering for application testers.
To address this, UiPath introduced Test Cloud as a dedicated platform designed specifically for application testing. RPA testing capabilities remain part of Automation Cloud, where they naturally belong alongside the broader automation platform.
Migrating from Test Suite to Test Cloud
If you are currently using Test Suite under the Flex licensing plan and want to move to Test Cloud under the Unified Pricing plan, refer to Migrate from Test Suite to Test Cloud for planning guidance and high-level migration steps.
¿Necesita ayuda? Soporte
