- Release Notes
- Requirements
- Getting Started
- Projects
- Datasets
- ML Packages
- Pipelines
- ML Skills
- ML Logs
- Document Understanding in AI Fabric
- Basic Troubleshooting Guide
- General AI Center Troubleshooting and FAQs
![](https://docs.uipath.com/_next/static/media/grid.05ebd128.png?w=3840&q=100)
Connection checking in progress
To fix this issue, follow the steps below:
- Quit the logs and check the status of the conn-checker pod
kubectl get pods
. - If you see Invalid Image Name displayed, try describing the pod:
kubectl describe <conn-checked-pod-name>
. - If the Failed to apply default image..
message is displayed in Events (bottom), this can mean that airgapped and non-airgapped are mixed:
- Check that infra and application are installed on the same pod.
- Check that the license is the same. Check the airgapped field in the
yaml
file to see if it is true or not and if this is expected.
- If the issue is with the license, this needs to be changed from the backend. Contact the person who provided the license and ask them to change it, or the AI Center team.
In case of host admin page errors (tenant provision error), use the solution below.
If there are a lot of evicted pods due to the error message above, this can slow down the machine or cause network issues. To solve this, use the solution below.
To solve this issue, run the following script or a similar one:
IFS=$'\)
for line in $(kubectl get pods -A | awk {'printf "%s,%s,%s\)
", $1,$2,$4'} | grep -E "Evicted"); do
ns=$(echo $line | cut -d',' -f1)
pod=$(echo $line | cut -d',' -f2)
kubectl delete pod -n $ns $pod
done
IFS=$'\)
done
If you want to monitor the progress of a pod while being called, you need to identify the pod corresponding to the skill and then connect to the Linux machine in order to check the logs while doing a prediction. For the most efficient way to do this, check the Solution section below.
For the most efficient way to identify a pod corresponding to a skill, follow the steps below.
- Go to the AI Center application.
- Go to the ML Skill page.
- Open network calls while inspecting page.
- Refresh the grid to get the ML Skill.
- Find the ML Skill call and preview it.
- Find the right ML Skill in the list and search
for tenant-id and id. Tenant id is the namespace and is the pod name.
- Once you have the above information, check
running logs by using the following
command:
kubectl -n <tenant-id> logs -f <id>
You can now call the skill and see the process in real time.
A pipeline failure takes place due to a file upload failure with an error message similar to the one below:
2021-04-30 20:59:43,397 - uipath_core.storage.local_storage_client:upload:132 - ERROR: Failed to upload file: logs/f5f7b9f4-0813-4107-a269-bf65de12444f/train.log.20210430205938 to bucket: training-8319b955-6187-43c3-a46f-612a9ea6f523, error: can't start new thread
2021-04-30 20:59:48,401 - uipath_core.utils.utils:_retries:172 - WARNING: Function: upload execution failed, retry count 1
Upgrade to a newer AI Center version (2021.4, for example) where this issue is fixed.
OR
If an upgrade is not a solution for the moment, delete the logs in the training pod using the following command:
kubectl -n <namespace> exec -it <pod_id> -- sh -c 'rm -rf /microservice/trainer_run_logs'
In the command above, the following variables are used:
namespace
- namespace of the pod. This can be obtained by running thekubectl get namespaces
command. Training namespaces start withtraining-
.pod_id
- pod id of the training pod. This can be obtained by running thekubectl get pod
in the training space above.
When running the import or export scripts, the following error message can occur:
./export.sh: line 2: $'\r': command not found
This error message is displayed when importing or exporting ML Packages using scripts.
- Issue: Provisioning Job Blocked in Connection Checking in Progress
- Solution
- Issue: Host Admin Page Errors
- Solution
- Message: Kubectl Get Pods -A | Grep Evicted
- Solution
- Issue Regarding ML Skills During Prediction
- Solution
- Issue While Pipeline Is Running
- Solution
- Message: ./export.sh: Line 2: $'\r': Command Not Found
- Solution
