Automation Suite
Banner background image
Automation Suite on EKS/AKS Installation Guide
Last updated May 20, 2024
SQL database
You must bring an external SQL server to install Automation Suite and UiPath® products. Microsoft SQL Server 2016, 2017, 2019, and 2022 Standard and Enterprise editions are supported.
Additional Microsoft SQL platforms, such as Azure SQL Database or Azure SQL Managed Instance or Amazon Relational Database Service, are also supported as long as the Microsoft SQL Server database engine meets the requirements. For details, see Compatibility matrix.
Note:
Make sure that the SQL server can be accessed from the cluster nodes.
Individual product support varies.
For each product you plan to deploy, you must:
  • check the supported version of SQL Server as required by the product;
  • meet the SQL Server configuration requirements, including SQL Server User permissions, as required by the product.
The general minimum hardware requirements for Microsoft SQL Server are as follows:
  • 8 (v-)CPU
  • 32 GiB RAM
  • 256 GiB SSD
The minimum requirements are general guidance and do not guarantee reliable operation in a production deployment. Capacity planning is required to determine the hardware requirements that are needed for reliable operation. For details, see Capacity planning.
Each UiPath® product requires its own SQL database.
Automatically create the necessary databases
If you want the installer to create the databases, fill in the following fields:
Parameter
sql.create_db
Set to true.
sql.server_url
FQDN of the SQL server, where you want the installer to configure database.
sql.port
Port number on which a database instance should be hosted in the SQL server.
sql.username
Username / user ID to connect to the SQL server.
sql.password
Password of the username provided earlier to connect to the SQL server.
Note:
Ensure the user has the dbcreator role. This grants them permission to create the database in SQL Server. Otherwise the installation fails.
ODBC connection does not support usernames that contain special characters. For database usernames for AI Center, Document Understanding, and Apps, use only uppercase and lowercase letters.
Bring your own database
If you choose to bring your own databases for a new Automation Suite installation, we strongly recommend setting up new databases rather than using existing ones. This precaution is necessary to prevent any conflicts with the operation of Automation Suite that might occur due to leftover metadata from old databases.
If you bring your own database, you must provide the SQL connection strings for every database. Automation Suite supports the following SQL connection string formats:
Parameter
Products
sql_connection_string_template
Full ADO.NET connection string where Catalog name is set to DB_NAME_PLACEHOLDER. The installer will replace this placeholder with the default database names for the installed suite services.
Platform, Orchestrator, Automation Suite Robots, Test Manager, Automation Hub, Automation Ops, Insights, Task Mining, Data Service, Process Mining, Document Understanding
sql_connection_string_template_jdbc
Full JDBC connection string where database name is set to DB_NAME_PLACEHOLDER. The installer will replace this placeholder with the default database names for the installed suite services.
AI Center
sql_connection_string_template_odbc
Full ODBC connection string where database name is set to DB_NAME_PLACEHOLDER. The installer will replace this placeholder with the default database names for the installed suite services.
Document Understanding, Apps
sql_connection_string_template_sqlalchemy_pyodbc
Full SQL alchemy PYODBC connection string where database name is set to DB_NAME_PLACEHOLDER. The installer will replace this placeholder with the default database names for the installed suite services.
Process Mining
Important:
Make sure the SQL account specified in the connection strings is granted the db_securityadmin and db_owner roles for all Automation Suite databases. If security restrictions do not allow the use of db_owner, then the SQL account should have the following roles and permissions on all databases:
  • db_securityadmin
  • db_ddladmin
  • db_datawriter
  • db_datareader
  • EXECUTE permission on dbo schema
Important:
If you manually set the connection strings in the configuration file, you can escape SQL, JDBC, ODBC, or PYODBC passwords as follows:
  • for SQL: add ' at the beginning and end of the password, and double any other '.
  • for JDBC/ODBC: add { at the beginning of the password and } at the end, and double any other }.
  • for PYODBC: username and password should be url encoded to account for special characters. Document Understanding database passwords cannot start with {.
Important: The AutomationSuite_ProcessMining_Airflow database for Process Mining product must have READ_COMMITTED_SNAPSHOT enabled.
Note:
By default, TrustServerCertificate is set to False, and you must provide an additional CA certificate for the SQL Server. This is required if the SQL Server certificate is self-signed or signed by an internal CA. If you do not provide the SQL Server certificate in this scenario, the prerequisite check will fail.
sql_connection_string_template example
Server=tcp:sfdev1804627-c83f074b-sql.database.windows.net:1433;Initial Catalog=DB_NAME_PLACEHOLDER;Persist Security Info=False;User Id=testadmin@sfdev1804627-c83f074b-sql.database.windows.net;Password=***;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;Server=tcp:sfdev1804627-c83f074b-sql.database.windows.net:1433;Initial Catalog=DB_NAME_PLACEHOLDER;Persist Security Info=False;User Id=testadmin@sfdev1804627-c83f074b-sql.database.windows.net;Password=***;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;
sql_connection_string_template_jdbc example
jdbc:sqlserver://sfdev1804627-c83f074b-sql.database.windows.net:1433;database=DB_NAME_PLACEHOLDER;user=testadmin;password=***;encrypt=true;trustServerCertificate=false;Connection Timeout=30;hostNameInCertificate=sfdev1804627-c83f074b-sql.database.windows.net"jdbc:sqlserver://sfdev1804627-c83f074b-sql.database.windows.net:1433;database=DB_NAME_PLACEHOLDER;user=testadmin;password=***;encrypt=true;trustServerCertificate=false;Connection Timeout=30;hostNameInCertificate=sfdev1804627-c83f074b-sql.database.windows.net"
sql_connection_string_template_odbc example
SERVER=sfdev1804627-c83f074b-sql.database.windows.net,1433;DATABASE=DB_NAME_PLACEHOLDER;DRIVER={ODBC Driver 17 for SQL Server};UID=testadmin;PWD=***;MultipleActiveResultSets=False;Encrypt=YES;TrustServerCertificate=NO;Connection Timeout=30;"SERVER=sfdev1804627-c83f074b-sql.database.windows.net,1433;DATABASE=DB_NAME_PLACEHOLDER;DRIVER={ODBC Driver 17 for SQL Server};UID=testadmin;PWD=***;MultipleActiveResultSets=False;Encrypt=YES;TrustServerCertificate=NO;Connection Timeout=30;"
sql_connection_string_template_sqlalchemy_pyodbc example
mssql+pyodbc://testuser%40sfdev3082457-sql.database.windows.net:_-%29X07_%5E3-%28%3B%25e-T@sfdev3082457-sql.database.windows.net:1433/DB_NAME_PLACEHOLDER?driver=ODBC+Driver+17+for+SQL+Server"mssql+pyodbc://testuser%40sfdev3082457-sql.database.windows.net:_-%29X07_%5E3-%28%3B%25e-T@sfdev3082457-sql.database.windows.net:1433/DB_NAME_PLACEHOLDER?driver=ODBC+Driver+17+for+SQL+Server"
sql_connection_string_template and sql_connection_string_template_sqlalchemy_pyodbc example (Process Mining)
"sql_connection_string_template": "Server=tcp:sfdev4515230-sql.database.windows.net,1433;Initial Catalog=DB_NAME_PLACEHOLDER;Persist Security Info=False;User Id=testadmin@sfdev4515230-sql.database.windows.net;Password='07<l[xj-=~:z`Ds&nl';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;"
"sql_connection_string_template_sqlalchemy_pyodbc": "mssql+pyodbc://testadmin%40sfdev4515230-sql.database.windows.net:07%3Cl%5Bxj-%3D~%3Az%60Ds%26nl@sfdev4515230-sql.database.windows.net:1433/DB_NAME_PLACEHOLDER?driver=ODBC+Driver+17+for+SQL+Server""sql_connection_string_template": "Server=tcp:sfdev4515230-sql.database.windows.net,1433;Initial Catalog=DB_NAME_PLACEHOLDER;Persist Security Info=False;User Id=testadmin@sfdev4515230-sql.database.windows.net;Password='07<l[xj-=~:z`Ds&nl';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;"
Default and optional DB names for Automation Suite services
  "orchestrator": "AutomationSuite_Orchestrator",
  "orchestrator_ta": "AutomationSuite_Orchestrator",
  "asrobots": "AutomationSuite_Orchestrator",
  "orchestrator_upd": "AutomationSuite_Platform",
  "platform": "AutomationSuite_Platform",
  "test_manager": "AutomationSuite_Test_Manager",
  "automation_ops": "AutomationSuite_Platform",
  "automation_hub": "AutomationSuite_Automation_Hub",
  "insights": "AutomationSuite_Insights",
  "task_mining": "AutomationSuite_Task_Mining",
  "dataservice": "AutomationSuite_DataService",
  "aicenter": "AutomationSuite_AICenter",
  "documentunderstanding": "AutomationSuite_DU_Datamanager",
  "processmining_airflow": "AutomationSuite_Airflow",
  "processmining_metadata": "AutomationSuite_ProcessMining_Metadata",
  "processmining_warehouse": "AutomationSuite_ProcessMining_Warehouse",
  "apps": "AutomationSuite_Apps",
Note:
If you you want to override the connection string for any of the services above, set the sql_connection_str for that specific service.
You still have to manually create these databases before running the installer.
Overriding the default connection string for Orchestrator and the platform
  "orchestrator": {
    "sql_connection_str": "Server=tcp:sfdev1804627-c83f074b-sql.database.windows.net,1433;Initial Catalog=CustomOrchDB;Persist Security Info=False;User Id=testadmin@sfdev1804627-c83f074b-sql.database.windows.net;Password=***;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;"
  "platform": {
    "sql_connection_str": "Server=tcp:sfdev1804627-c83f074b-sql.database.windows.net,1433;Initial Catalog=CustomIDDB;Persist Security Info=False;User Id=testadmin@sfdev1804627-c83f074b-sql.database.windows.net;Password=***;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;"
  "orchestrator": {
  "platform": {
To override the database connection strings for other products, set the sql_connection_str in the corresponding product blocks. The connection string should have a format supported by the respective product.
Example for setting database connection string for AI Center
Parameter
aicenter.sql_connection_str
AI Center JDBC connection string (Refer below for the JDBC format)
Note: Make sure the JDBC connection string has the format in the following sample:
"aicenter": {
    "enabled": true,
    "sql_connection_str": "jdbc:sqlserver://sfdev1804627-c83f074b-sql.database.windows.net;database=aicenter;user=testadmin@sfdev1804627-c83f074b-sql.database.windows.net;password=TFgID_9GsE7_P@srCQp0WemXX_euHQZJ"
}"aicenter": {
    "enabled": true,
Sample Document Understanding connection string
"documentUnderstanding": {
  "datamanager": {
    "sql_connection_str": "SERVER=sql-server.database.windows.net;DATABASE=datamanager;DRIVER={ODBC Driver 17 for SQL Server};UID=testadmin;PWD=myPassword"
  "sql_connection_str": "Server=tcp:database.example.com,1433;Initial Catalog=db;Persist Security Info=False;User Id=testadmin@example.com;Password=***;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;",
  "cjkOcr":
    "enabled": true
}"documentUnderstanding": {
  "datamanager": {
  "cjkOcr":
    "enabled": true
Note: The data manager SQL connection string is optional only if you want to overwrite the default with your own.
Handwriting is always enabled for online installation.
The default value for max_cpu_per-pod is 2, but you can adjust it according to your needs.
Sample Process Mining connection string
"processmining": {
    "enabled": true,
    "warehouse": {
        "sql_connection_str": "Server=tcp:sfdev4515230-sql.database.windows.net,1433;Initial Catalog=AutomationSuite_ProcessMining_Warehouse;User Id=testadmin@sfdev4515230-sql.database.windows.net;Password='07<l[xj-=~:z`Ds&nl';Persist Security Info=False;Integrated Security=true;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;",
	"sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://testadmin%40sfdev4515230-sql.database.windows.net:07%3Cl%5Bxj-%3D~%3Az%60Ds%26nl@sfdev4515230-sql.database.windows.net:1433/AutomationSuite_ProcessMining_Warehouse?driver=ODBC+Driver+17+for+SQL+Server&TrustServerCertificate=YES&Encrypt=YES&Trusted_Connection=yes",
        "master_sql_connection_str": "Server=tcp:sfdev4515230-sql.database.windows.net,1433;Initial Catalog=master;Persist Security Info=False;Integrated Security=true;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;"
    "sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://testadmin%40sfdev4515230-sql.database.windows.net:07%3Cl%5Bxj-%3D~%3Az%60Ds%26nl@sfdev4515230-sql.database.windows.net:1433/AutomationSuite_Airflow?driver=ODBC+Driver+17+for+SQL+Server&TrustServerCertificate=YES&Encrypt=YES"
    "sql_connection_str": "Server=tcp:sfdev4515230-sql.database.windows.net,1433;Initial Catalog=AutomationSuite_ProcessMining_Metadata;User Id=testadmin@sfdev4515230-sql.database.windows.net;Password='07<l[xj-=~:z`Ds&nl';Persist Security Info=False;Integrated Security=true;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;",
},"processmining": {
    "enabled": true,
    "warehouse": {
Important: that the names for template PYODBC connection string sql_connection_string_template_sqlalchemy_pyodbc and the PYODBC connection string sqlalchemy_pyodbc_sql_connection_str used when you bring your own database are different. Also connection string names are different for the template SQL sql_connection_string_template and sql_connection_str used when you bring your own database.
Important:
If you bring your own database and you configured this using the sql_connection_str and sqlalchemy_pyodbc_sql_connection_str connection strings in the processmining section of the input.jsonfile, the template connection strings sql_connection_string_template and sql_connection_string_template_sqlalchemy_pyodbc are ignored if specified.
Attention:
MultiSubnetFailover=True is not supported. Make sure to remove MultiSubnetFailover=True from any of the Process Mining connection strings.
Note: Depending on the app_security_mode setting either a new SQL user is created for every Process Mining app by the system (app_security_mode="system_managed"), or a single SQL user account is created that is used for all process apps (app_security_mode="single_account"). Note that app_security_mode="system_managed" is the default setting, and that this requires advanced permissions for the database user.
  • Scenario: setup with Kerberos authentication.
"processmining": {
    "enabled": true,
    "warehouse": {
        "sql_connection_str": "Server=tcp:assql2019.autosuitead.local,1433;Initial Catalog=AutomationSuite_ProcessMining_Warehouse;Persist Security Info=False;Integrated Security=true;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;",
        "sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://:@assql2019.autosuitead.local:1433/AutomationSuite_ProcessMining_Warehouse?driver=ODBC+Driver+17+for+SQL+Server&TrustServerCertificate=YES&Encrypt=YES&Trusted_Connection=yes",
        "master_sql_connection_str": "Server=tcp:assql2019.autosuitead.local,1433;Initial Catalog=master;Persist Security Info=False;Integrated Security=true;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;"
    "sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://:@assql2019.autosuitead.local:1433/AutomationSuite_Airflow?driver=ODBC+Driver+17+for+SQL+Server&TrustServerCertificate=YES&Encrypt=YES&Trusted_Connection=yes"
    "enabled": true,
    "warehouse": {
  • Scenario: Metadata database and data warehouse use separate SQL server (Non-Kerberos authentication).
"processmining": {
    "enabled": true,
    "warehouse": {
      "sql_connection_str": "Server=tcp:uipath-integration1.database.windows.net,1433;Initial Catalog=AutomationSuite_ProcessMining_Warehouse;Persist Security Info=False;User Id=userid;Password='password';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;",
      "sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://userid:password@uipath-integration1.database.windows.net:1433/AutomationSuite_ProcessMining_Warehouse?driver=ODBC+Driver+17+for+SQL+Server&TrustServerCertificate=YES&Encrypt=YES",
      "master_sql_connection_str": "Server=tcp:uipath-integration1.database.windows.net,1433;Initial Catalog=master;Persist Security Info=False;User Id=userid;Password='password';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;"
    "sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://userid:password@uipath-integration2.database.windows.net:1433/AutomationSuite_Airflow?driver=ODBC+Driver+17+for+SQL+Server&TrustServerCertificate=YES&Encrypt=YES"
    "sql_connection_str": "Server=tcp:uipath-integration2.database.windows.net,1433;Initial Catalog=AutomationSuite_Airflow;Persist Security Info=False;User Id=userid;Password='password';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;",
    "enabled": true,
    "warehouse": {
  • Scenario: using custom app_security_mode.
"processmining": {
    "enabled": true,
    "app_security_mode": "system_managed",
    "warehouse": {
    "sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://:@assql2019.autosuitead.local:1433/AutomationSuite_Airflow?driver=ODBC+Driver+17+for+SQL+Server&TrustServerCertificate=YES&Encrypt=YES&Trusted_Connection=YES"
    "enabled": true,
    "warehouse": {
Azure Active Directory based access to SQL from AKS
You may choose to access Microsoft SQL server via Azure Active Directory from AKS cluster. The following example shows some connections strings using the AAD access method:
"sql_connection_string_template": "Server=tcp:sfdev3888449-sql.database.windows.net,1433;Authentication=Active Directory Service Principal;Initial Catalog=DB_NAME_PLACEHOLDER;Persist Security Info=False;User Id=5c6b8ff1-efb4-48ca-a530-f744f1d438df;Password='I5V8Q~srSTWf0onUYeHLK..qLO69pP7MZ3KIMaB2';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;",
  "sql_connection_string_template_jdbc": "jdbc:sqlserver://sfdev3888449-sql.database.windows.net;authentication=ActiveDirectoryServicePrincipal;database=DB_NAME_PLACEHOLDER;user=5c6b8ff1-efb4-48ca-a530-f744f1d438df;password={I5V8Q~srSTWf0onUYeHLK..qLO69pP7MZ3KIMaB2};encrypt=true;trustServerCertificate=false;hostNameInCertificate=*.database.windows.net;loginTimeout=30;",
  "sql_connection_string_template_odbc": "SERVER=sfdev3888449-sql.database.windows.net;Authentication=ActiveDirectoryServicePrincipal;DATABASE=DB_NAME_PLACEHOLDER;DRIVER={ODBC Driver 17 for SQL Server};UID=5c6b8ff1-efb4-48ca-a530-f744f1d438df;PWD={I5V8Q~srSTWf0onUYeHLK..qLO69pP7MZ3KIMaB2};Encrypt=yes;TrustServerCertificate=no;Connection Timeout=30;hostNameInCertificate=sfdev3888449-sql.database.windows.net",
  "sql_connection_string_template_sqlalchemy_pyodbc": "mssql+pyodbc://5c6b8ff1-efb4-48ca-a530-f744f1d438df:I5V8Q~srSTWf0onUYeHLK..qLO69pP7MZ3KIMaB2@sfdev3888449-sql.database.windows.net:1433/DB_NAME_PLACEHOLDER?driver=ODBC+Driver+17+for+SQL+Server&authentication=ActiveDirectoryServicePrincipal",  "sql_connection_string_template": "Server=tcp:sfdev3888449-sql.database.windows.net,1433;Authentication=Active Directory Service Principal;Initial Catalog=DB_NAME_PLACEHOLDER;Persist Security Info=False;User Id=5c6b8ff1-efb4-48ca-a530-f744f1d438df;Password='I5V8Q~srSTWf0onUYeHLK..qLO69pP7MZ3KIMaB2';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;",
SQL requirements for AI Center
Requirements for AI Center installed on a FIPS 140-2-enabled machine
To install AI Center on a FIPS 140-2-enabled machine, take the following steps:
  1. Before starting the Automation Suite installation, take the following steps:
    1. Enable FIPS 140-2 on the machine on which you plan to install Microsoft Server by following the Microsoft instructions.
    2. Install Microsoft SQL Server on the FIPS 140-2-enabled machine.
    3. Get the Microsoft SQL Server certificate by running the following command from the SQL Server or any server that can connect to the SQL server with the configured SQL host name:
      nmap -sV -p <port> -vv --script ssl-cert domainnmap -sV -p <port> -vv --script ssl-cert domain
  2. During the Automation Suite installation, take the following steps:
    1. Append the following values to the AI Center sql_connection_string_template_jdbc connection string in the cluster_config.json file: encrypt=true;trustServerCertificate=false;fips=true;.
      Example:
      jdbc:sqlserver://sfdev1804627-c83f074b-sql.database.windows.net:1433;database=DB_NAME_PLACEHOLDER;user=testadmin;password=***;encrypt=true;trustServerCertificate=false;fips=true;Connection Timeout=30;hostNameInCertificate=sfdev1804627-c83f074b-sql.database.windows.net"jdbc:sqlserver://sfdev1804627-c83f074b-sql.database.windows.net:1433;database=DB_NAME_PLACEHOLDER;user=testadmin;password=***;encrypt=true;trustServerCertificate=false;fips=true;Connection Timeout=30;hostNameInCertificate=sfdev1804627-c83f074b-sql.database.windows.net"
      For details on database configuration, see Advanced installation experience and Updating the SQL database.
    2. Add the exported cert from step 1.c. to the trust store of the host machine. For details see Updating the CA Certificates.
