Automation Suite
Automation Suite Admin Guide
Last updated May 20, 2024
Managing Access
This page describes how to control the functionality and products that an account can access. Predefined groups and roles exist for easy setup, but you can also create custom ones if you want to apply a layered and flexible access scheme.
Roles
Roles are a collection of permissions and represent a more granular layer for managing user access, following the broader option of maintaining access through groups. You can add roles to either groups so that all member accounts inherit them, or to individual accounts.
Roles can include several permissions at either the organization level, or at the service level, so there are:
  • organization-level roles: these roles control the permissions that accounts have on organization-wide options; they are available in the Automation Suite portal by default and you cannot change them, nor can you add new ones;
  • service-level roles: these roles control the access rights and actions that accounts can perform in each UiPath® service you own; they are managed from within each service and can include default roles which you cannot change, as well as custom roles that you create and manage in the service.
Accounts and groups typically have an organization-level role and one or more service-level roles.
Groups and Roles
In the following table you can see the roles that are assigned to accounts when they are added to a group.
For example, adding an account to the Administrators default group grants them the Organization Administrator role for the organization and the Administrator role in the Orchestrator service. So this user can manage both organization-level roles from Accounts and Groups, as well as service-level roles in Orchestrator.
Group Membership
Organization-level Role
Service-level Roles for Orchestrator
Administrators
Automation Users
Automation User at folder level 1
Automation Developers
Folder Administrator at folder level 1
Everyone
No roles.
[Custom group]
No roles by default, but you can add roles to the group as needed.
1 The roles are assigned for the Shared modern folder, if it exists.
Note: For information about roles across UiPath services, see Role management.
Organization-level Roles
Accounts can have only one organization-level role. This role controls the access that the account has to options within the portal areas of Automation Suite, such as the tabs they can see on the Admin page or the options available to them on the Home and Admin pages.
At organization level, the roles Organization Administrator and User are available.
You cannot change these roles or add new roles at the organization level.
Organization administrator
This role grants access to every organization- and service-level feature within the organization. An account with this role can perform all administrative actions for the organization, such as creating or updating tenants, managing accounts, viewing organization audit logs, and so on. There can be multiple accounts with this role.
The first organization administrator for any given organization is appointed when the organization is created.
To grant this role to others, the organization administrator can add user accounts to the Administrators group, which is one of the default groups.
The organization administrator role includes the following organization-level permissions, which cannot be changed:
View
Edit
Create
Delete
Admin option in left rail
Usage charts and graphs
Tenants
Accounts and groups
Authentication settings
External applications
Licenses
API keys
Resource center (Help)
Audit logs
Organization settings
User
This is the basic level of access within the UiPath ecosystem and allows users to log in and access the Home page.
Local user accounts automatically become members of the Everyone group, which grants them the User role. This role is also granted to all accounts that are in the default groups Automation Users and Automation Developers.
For directory accounts, you must manually add them to the Everyone,Automation Users, or Automation Developers group to assign this role and grant them access.
You can also add a directory group to one of these default groups to grant the User role (and any service-level roles defined for the default group) to all members of that group.
Service-level Roles
Service-level roles control access rights and permitted actions within each of your UiPath services, such as the Orchestrator service, Data Service, or AI Center. The permissions for each service are managed within the service itself, not from the Automation Suite Admin page.
To grant permissions for a service to accounts, you can:
  • assign service-level roles to a group to grant those roles to all member accounts - you do this in the service;
  • add accounts to a group that already has the required service-level roles - you do this from Admin > Accounts and Groups;
  • assign roles to an account - you do this in the service.
Role Management
You can manage and assign service-level roles from within each service and you need the appropriate permissions in the service. For example, users with the Administrator role in Orchestrator can create, edit, and assign roles.
Assigning Organization-level Roles
Organization-level roles are predefined and cannot be changed.
Organization administrators can assign organization-level roles to individual accounts from Admin > Accounts and Groups by adding accounts to a default or custom group.
See Groups and roles for more information about the organization-level roles tied to each type of group.
Note:
If you have linked your Automation Suite organization to a directory, such as Azure Active Directory (Azure AD), then it is possible to also assign organization-level roles to directory groups by adding them to groups, same as with accounts. This is not possible with local groups.
For more infromation, see Types of groups.
Managing Service-level Roles
You manage and assign service-level roles from within the services. You can assign roles to groups (recommended), or to accounts that have already been added in Automation Suite.
For information and instructions, see the applicable documentation:
Service
Details
Orchestrator
Managed from Orchestrator.
For more information and instructions, see About Roles in the Orchestrator documentation.
Actions
and
Processes
  • For the list of permissions required, see Roles and Permissions in the Action Center documentation.
  • For instructions on assigning roles, see About Roles in the Orchestrator documentation.
Automation Hub
and
Automation Store
Managed from Automation Hub.
For more information about which roles are required and instructions for assigning them, see Role Description and Matrix in the Automation Hub documentation.
AI Center
Data Service
Managed from Data Service.
  • For more information and instructions, see Managing Access in the Data Service documentation.
Task Mining
Managed using Automation Suite organization-level roles.
  • For information about the rights that organization-level roles grant in Task Mining, see Managing Access in the Task Mining documentation.
  • For instructions on how to assign organization-level roles, see Managing accounts and groups in the Automation Suite documentation.
Process Mining
Managed from Process Mining.
  • For more information and instructions on how to enable users to work with Process Mining, see Setting up the users in the Process Mining documentation.
Assigning Roles to an Account
If you want to granularly control the access a certain account has in a service, but you don't want to add new roles to an entire group, you can explicitly add the account to the service and assign one or more service-level roles to it directly. For example, you can add an account to the Orchestrator service.
For information about the available roles and instructions, see the documentation for the target service, as described above.
