solutions-management
解决方案用户指南
  • 简介
  • 入门指南
  • 管理解决方案项目和包
  • 管理解决方案部署
    • 部署解决方案
    • 部署状态
    • 编辑解决方案
    • 升级或降级解决方案
    • 卸载解决方案
    • 导航“部署”侧边栏
    • 解决方案调试部署的保留和自动清理
  • 最佳实践
请注意,此内容已使用机器翻译进行了本地化。 新发布内容的本地化可能需要 1-2 周的时间才能完成。
导航“部署”侧边栏
Deployments sidebar contents and management options for inspecting and acting on solution deployments in Automation Suite.
概述​
The Deployments sidebar provides a contextual view of a solution's deployment directly from the Deployments tab. It lets you inspect deployment details and manage your deployment without leaving the Deployments page.
At the top of the sidebar, you can see the deployment's title, its version (whether it is the latest or if a newer version is available), its status (Pending, Failed, or Active), and a brief description, if available.
Below the header, you can see the activation status of the deployment, its folder path location (selectable, so you can navigate to the solution folder), its last operation, and when it was last performed.
展开“部署” 侧边栏​
要展开部署侧边栏,请执行以下操作:
  1. 导航至Orchestrator >解决方案。
  2. 选择“部署”选项卡。
  3. 从列表中选择解决方案部署。
“部署”侧边栏将在屏幕右侧打开,并在您浏览部署信息时保留在上下文中。
提示:
If your deployment is successfully installed and activated, you can select Deployment details from the Deployment logs and navigate directly to the Deployments sidebar.
从侧边栏管理部署​
Depending on the state of your deployment, you may be able to take the following actions:
备注:
Regardless of a deployment's status or activation readiness, you can select Uninstall or Edit. If a deployment was uninstalled, you can also delete it.
部署状态激活状态可用操作
安装 - 成功活动Select Go to folder to navigate to the solution's folder in Orchestrator.
配置更改 - 草稿活动Select Continue if you were in the middle of changing your deployment's configuration.
安装 - 成功需要设置才能激活Select Set up activation to configure your solution for activation readiness.
安装 - 成功准备激活选择“激活部署” 。
安装 - 正在进行不适用无可用操作。
配置更改 - 成功活动选择“更改版本”以升级您的配置。
在“资源”选项卡上,您可以查看解决方案中包含的所有组件的列表,包括流程、连接、触发器、资产和存储桶。
For each deployment, you can view details regarding its history and select Refresh to get the most recent view.
提示:
如果您已对部署执行 20 次以上的操作,请增加“历史记录”表格中显示的项目数量。
列描述
版本已部署的解决方案版本。
上次操作对部署执行的最新操作,例如安装、卸载、激活设置、升级、降级、配置更改或回滚。
状态部署的当前状态。
已开始自部署开始以来经过的时间。
作者执行操作的用户的用户名。
  • 概述​
  • 展开“部署” 侧边栏​
  • 从侧边栏管理部署​
  • “历史记录”选项卡导航​
此页面有帮助吗?
连接
需要帮助? 支持
想要了解详细内容? UiPath Academy
有问题? UiPath 论坛
保持更新
