# Hardware and Software Requirements
> :::important
The hardware and software requirements presented in this document refers to the minimum and recommended resources needed for one robot to run automations. Workflow complexity and additional software installed on the machine might affect the robot's performance.
## Hardware Requirements
:::important
|  | Minimum | Recommended |
| **CPU** (*) | 2 x 1.8GHz 32-bit (x86) | 4 x 2.4GHz 64-bit (x64) |
| **RAM** | 4 GB | 8 GB |
| **Disk Space** | 3.5 GB for new installations, 5 GB for upgrades (including temporary files required during installation) | N/A |
(*) UiPath does not support the ARM architecture on Windows.
You can also check out hardware requirements for [Studio](https://docs.uipath.com/studio/standalone/2022.4/user-guide/hardware-and-software-requirements) and [Orchestrator](https://docs.uipath.com/orchestrator/standalone/2022.4/installation-guide/orchestrator-hardware-requirements).
## Software Requirements
<colgroup>
<col/>
<col/>
<col/>
</colgroup>
Supported Versions
Particularities
Operating System
Windows 8.1
Windows 8.1 N
Windows 10
Windows 10 N
Windows 11
Microsoft Azure Windows 10 Enterprise Multi-Session
Works in conjunction with Azure Virtual Desktop (AVD) as well.<code>1</code>
Supports Windows 365 machines.
Windows Server 2012 R2
Windows Server 2016
Windows Server 2019
Windows Server 2022
Windows Server Core 2016
Windows Server Core 2019
Windows Server Core 2022
Can only run background unattended jobs.
The jobs run under the local system account by default. To use a specific user (credentials specified in Orchestrator), you
                                 need to configure the <code>UIPATH_HEADLESS_WITH_USER</code> environment variable on the robot machine and set the value to <code>True</code>.
Citrix environments
XenApp v6.5 or greater
XenDesktop v7.0 or greater
.NET Framework
Version 4.6.1 or greater
If your machine runs Windows OS in a language other than English, install the corresponding language pack for the .Net framework
                                 version you are using.
This is required for running Studio in any of the available languages. The .Net framework and related language pack version
                                 must correspond, and any conflicting .Net framework versions installed on the machine should be removed.
Web Browsers (for browser automation)
Internet Explorer v8.0 or greater
Google Chrome version 64 or greater
Automated with the extension for Chrome or the Webdriver protocol.
Mozilla Firefox version 52.0 or greater
Automated with the extension for Firefox or the Webdriver protocol.
Microsoft Edge on Windows 10 version 1803 or greater
Automated with the extension for Edge.
Microsoft Office (for projects created in the StudioX profile)
Office: 2013
Office: 2016
Office: 2019
Office 365
IP
IPv4
IPv6
Assistant can be installed on IPv6-compatible operating systems.
:::important
`1` When using unattended robots on Virtual Machines, do not leave the Azure Virtual Desktop sessions in `disconnected` state *(user is connected to a host pool in an AVD environment, but they are still connected to the session hosts)*. The robot is not able to use the disconnected session as it was created via AVD and does not have access to it. Because of this, it attempts to create a new session to run the unattended job, but fails because the AVD session is already created and in `disconnected` state. When this scenario happens, the job eventually fails due to a time out.
