# 2023.4.10
> Dbt projects now run with **dbt version 1.8.4**. Check out the official [dbt documentation](https://docs.getdbt.com/docs/introduction) to make use of the latest **dbt** functionalities.
## Release date: December 18, 2024
### Data transformations
With the introduction of unit tests in **dbt version 1.8**, the `tests:` key was renamed to `data_tests:`. For existing process apps, this results in a deprecation warning that is displayed when loading data or opening **Data transformations.**
`[WARNING]: Deprecated functionality The `tests` config has been renamed to `data_tests`. Please see https://docs.getdbt.com/docs/build/data-tests#new-data_tests-syntax for more information.`
For default process apps, you can rename the occurrences of the `tests:` config to `data_tests:` in the `dbt_project.yml` and the `sources.yml` files to fix this. For customized process apps, this can be present in other `.yml` files as well.
Check out the official **dbt** documentation on the [New `data_tests:` syntax](https://docs.getdbt.com/docs/build/data-tests#new-data_tests-syntax) for more information.
We are constantly striving to improve your **UiPath® Process Mining** experience. While this release brings no major changes, we included security and accessibility improvements, as well as minor bug fixes.
