# Troubleshooting CData Sync
> Common issues with CData Sync in Process Mining on Automation Suite, including how to access job logs for diagnosing failed or unexpected sync operations.
## Introduction
When a CData Sync job is not working as expected, there are several ways to get more information about what might have gone wrong.
## Job logs
You can check the job logs for more information about a specific log. Follow these steps to check the job logs in CData Sync.
1. Select **Logs** in the CData Sync menu bar.
2. On the **Job History** tab, locate the job for which you want to donwload the logs.
3. Select **Download Logs** from the menu.
Refer to the official CData Sync documentation on [Logs and History](https://cdn.cdata.com/help/ASK/sync/Logging-History.html) for more details.
## Application logs
When the job logs do not provide adequate information, you can check the Application log of the CData Sync server. The Application log contains more detailed information about all jobs being run. This can be helpful when analyzing pre-job and post-job events.
Follow these steps to view the CData Sync application log.
2. Go to the **Application** tab and select **Download Logs**.
Refer to the official CData Sync documentation on [Application Logs](https://cdn.cdata.com/help/ASK/sync/Application-Logs.html) for more details.
