# Process Mining troubleshooting and FAQs
> The purpose of this Troubleshooting page is to serve as a knowledge base for common problems faced or questions asked when using **UiPath® Process Mining**. It does not provide a complete list of all problems you may encounter, but is intended to provide guidance with the most common issues. If you encounter any issues that are not covered here, feel free to reach out to [UiPath® Technical Support](https://www.uipath.com/company/contact-us/contact-technical-support).
## Introduction
### Message: The HTTP status code of the response was not expected (500)
When creating a new process app using sample data, the following error message can occur:
![docs image](https://dev-assets.cms.uipath.com/assets/images/process-mining/process-mining-20569-c6962b0f.webp)
#### Possible cause
A SQL Server password has changed. Check out [Configuring Microsoft SQL Server](https://docs.uipath.com/automation-suite/automation-suite/2022.10/installation-guide/updating-the-sql-database).
#### Solution
Update Automation Suite when changing SQL Server credentials.
### Message: [Errno 2] No such file or directory: '/dbt/dags/workflows/execdbt//target/4212eba4-1edc-4b9c-9c04-1d59c2bfe0af/run_results.json'
![docs image](https://dev-assets.cms.uipath.com/assets/images/process-mining/process-mining-337226-2f724556.webp)
#### Possible cause
The content of the uploaded transformation package is incorrect, by an incorrect zip action.
#### Solution
Make sure the content of the `.zip` file that contains the transformations is correct.
#### Possible cause
Kerberos setup is used for login to Automation Suite and Kerberos setup is **not** used for SQL authentication. The `enableSqlIntegratedAuth` configuration flag determines whether or not integrated SQL authentication setup is used for SQL authentication. If the `enableSqlIntegratedAuth` configuration flag is set to **true**, this implies that Kerberos setup is not used for authentication. To solve the issue, the `enableSqlIntegratedAuth` configuration flag must set to **false** which disables integrated SQL authentication and ensures that Kerberos setup is used for authentication.
#### Possible solution
Follow these steps to set the `enableSqlIntegratedAuth` flag to **false**.
1. In the ArgoCD Experience, enter **Airflow** in the search bar and open the card.
2. Select **App Details** and go to the **Details** tab.
3. Edit the **VALUES** and set the flag `enableSqlIntegratedAuth` to **false**. Select **SAVE**.
   ![docs image](https://dev-assets.cms.uipath.com/assets/images/process-mining/process-mining-337422-5af86142.webp)
4. Locate the **SYNC POLICY** section and set **AUTOMATED** to **DISABLE AUTO-SYNC** for the Airflow app, to ensure the configuration flag `enableSqlIntegratedAuth` will not be brought back to **true.**
   ![docs image](https://dev-assets.cms.uipath.com/assets/images/process-mining/process-mining-337417-fd2cf188.webp)
### Message: File upload failed due to the following error: Network error
When uploading data using **.csv** or **.tsv** files, the following error message can occur:
![docs image](https://dev-assets.cms.uipath.com/assets/images/process-mining/process-mining-82234-81891f91.webp)
#### Possible cause
Incorrect or missing HTTPS certificate.
#### Solution
The HTTPS certificate used by the BLOB store must be valid in your browser. Check the error and make sure to get the appropriate certificates.
1. Go the **Process Mining** portal and press **F12** to open the Developer tools.
Check the **Console** and **Network** tabs for the ERR: CERT_AUTHORITY_INVALID error. This indicates an error with the trust of the HTTPS certificate. The following illustration shows an example.
![Developer tools](https://dev-assets.cms.uipath.com/assets/images/process-mining/process-mining-82238-0e973e4e.webp)
2. Contact your IT department to install the certificate chain of the authority listed in the error and to add it to the trusted certificate store in operating system for all user that will be using the system. For example, pmcprddatawesa.blob.core.windows.net.
### Message: utf-8 codec can't decode byte &lt;byte&gt; in position &lt;position&gt;: Invalid start byte
The following message is displayed in the data run log.
![docs image](https://dev-assets.cms.uipath.com/assets/images/process-mining/process-mining-82252-2f144bfa.webp)
#### Possible cause
One or more input files you uploaded have an unexpected encoding.
#### Solution
Set the encoding to **UTF-8** and set **CR/LF** end of line characters (Windows style).
You can change these settings in a file editor. For example in Notepad++.
1. Open the datasource file in Notepad++.
2. Go to **Edit -&gt; EOL Conversion** and select **Windows CR LF**.
3. Go to **Encoding** and select **Convert to UTF-8**.
4. Save the file.
### Connection error: The TCP/IP connection to the host &lt;host&gt;, port &lt;port&gt; has failed.
The following message is displayed when setting up a SQL Server destination connection in CData Sync.
![docs image](https://dev-assets.cms.uipath.com/assets/images/process-mining/process-mining-100089-b1ce5410.webp)
#### Possible cause
There is an issue with CData Sync connecting to SQL Server.
#### Solution
* Open SQL Server Configuration Manager.
* Check the **TCP Port** number.
* Check if **TCP/IP** is set to **Enabled** for the Port. The following illustrations shows an example.
  ![SQL Server Configuration maganager for TCP port configuration](https://dev-assets.cms.uipath.com/assets/images/process-mining/process-mining-100095-6a46aa25.webp)
