# Deleting input tables
> Delete input tables from a process app in Process Mining on Automation Suite when the data is no longer needed.
:::note
You can delete input tables that you do not need anymore. Deleting an input table removes the data for your process app. If you want to use the data in your process app at a later stage, you must re-upload the input table.
Follow these steps to delete an input table from the Input data list.
1. Locate the input table you want to delete.
2. Select the context menu icon and select **Delete**. A confirmation message is displayed.
3. Select **Delete** to delete the input table.
The input table is no longer available in the **Tables** section.
