# 2.2510.0-patch2
> 2.2510.0-patch2 release notes for Process Mining in Automation Suite.
**Release date: March 16, 2026**
This patch resolves issues affecting data loading and application editing in Process Mining deployments with large datasets.
## Bug fixes
### Data loading
Uploading data failed for applications with a large number of columns because the resulting column-metadata query exceeded SQL Server's 8,000-character limit; Process Mining now handles large column sets correctly.
### Data Manager
Applications with more than 500 fields could no longer be edited because incorrect field counting allowed the total to exceed Process Mining's 500-field limit during the initial run. Field counting now works correctly, and applications remain editable within the defined limit.
### CData data ingestion
Data refreshes after the initial CData ingestion did not load new data into the ELT editor or dashboards because an incorrect check bypassed the mapping execution step when the data mapping was unchanged between ingestions. The check is now corrected, and CData data refreshes load updated data as expected.
