industry-department-solutions
此内容在所选语言中不可用。系统会改为显示英文内容。
Manufacturing orders dataset
Manufacturing orders dataset containing historical and planned manufacturing orders per product and factory location, used by Inventory Management to project future inventory availability.
The manufacturing orders dataset contains historical and planned manufacturing orders for each product at each factory location. It is used by the inventory management solution to project future inventory availability.
Purpose​
The solution uses manufacturing order data to understand incoming supply from production. By combining placed and planned orders with expected and actual production dates and quantities, the solution can project future inventory availability and support replenishment and stock optimization recommendations.
Required fields​
About the Constraint column: every field listed must be provided in your data. Non-null means its value cannot be null; Nullable means the value may be sent as null (or left blank in your source). Primary key, Unique, and Foreign key describe the field's role in the data model; a Primary key is always non-null.
FieldDescriptionTypeConstraint
product_idUnique identifier for the manufactured product.stringPrimary key
location_idUnique identifier for the factory location.stringPrimary key
order_numberUnique identifier for the manufacturing order.stringPrimary key
source_idIdentifier of the source or supplier associated with the order.stringNon-null
ordered_atDate and time the manufacturing order was placed.datetimeNon-null
ordered_unitsNumber of units ordered for manufacture.integerNon-null
expected_start_datePlanned start date and time for production.datetimeNon-null
actual_start_dateActual start date and time for production.datetimeNullable
expected_end_datePlanned completion date and time.datetimeNon-null
actual_end_dateActual completion date and time.datetimeNullable
produced_unitsNumber of units actually produced.integerNullable
statusCurrent status of the manufacturing order.stringNullable
Usage notes​
  • This dataset is optional and relevant when inventory is replenished through in-house manufacturing.
  • Product and location identifiers must align with the corresponding Products and Locations datasets.
  • Both planned and actual dates should be provided where available to support accurate availability projections.
  • Quantities should use the same unit of measure as related datasets.
  • Purpose​
  • Required fields​
  • Usage notes​
此页面有帮助吗?
连接
需要帮助? 支持
想要了解详细内容? UiPath Academy
有问题? UiPath 论坛
保持更新
