industry-department-solutions
此内容在所选语言中不可用。系统会改为显示英文内容。
Forecast dataset
Forecast dataset containing demand forecast values per product and location, an optional forward-looking demand signal for Inventory Management.
The forecast dataset contains demand forecast values for each product at each location. It provides an optional forward-looking demand signal that customers can supply if they already produce their own forecasts.
Purpose​
The inventory management solution uses forecast data as an additional demand signal to complement historical demand analysis. When customers already generate their own forecasts, this dataset allows those forward-looking values to inform replenishment and stock optimization recommendations.
Required fields​
About the Constraint column: every field listed must be provided in your data. Non-null means its value cannot be null; Nullable means the value may be sent as null (or left blank in your source). Primary key, Unique, and Foreign key describe the field's role in the data model; a Primary key is always non-null.
FieldDescriptionTypeConstraint
product_idUnique identifier for the product.stringPrimary key
location_idUnique identifier for the store or distribution centre.stringPrimary key
cutoff_dateThe date on which the forecast was generated.datePrimary key
start_dateFirst date of the forecast period.datePrimary key
end_dateLast date of the forecast period.dateNon-null
horizonNumber of periods ahead of the cutoff date that the forecast covers.integerNon-null
yhatForecasted demand value for the period.floatNon-null
frequencyLength of the forecast period, in days.integerNon-null
Usage notes​
  • This dataset is optional and only required when customers already produce their own demand forecasts.
  • Product and location identifiers must align with the corresponding Products and Locations datasets.
  • Forecast periods should be consistent, with frequency defining the length of each period in days.
  • Forecast values should reflect expected demand, not historical actuals.
  • Purpose​
  • Required fields​
  • Usage notes​
此页面有帮助吗?
连接
需要帮助? 支持
想要了解详细内容? UiPath Academy
有问题? UiPath 论坛
保持更新
