industry-department-solutions
- Overview
- API Resources
此内容在所选语言中不可用。系统会改为显示英文内容。
Product
product API resource for the B2B pricing application, with categorization and bespoke product indicators used in quote pricing scenarios.
The product resource represents product entities in the B2B pricing application. This resource stores product information including categorization and bespoke product indicators.
→ For business context (purpose, usage notes, how this resource is used in the solution), see Products dataset in the User Guide.
Resource Endpoint
/api/v2/ingest/object/{prefix}PRODUCT{suffix}
Supported Methods
| Method | Return Type | Description |
| POST | Response | Ingest (create/update) product records via UPSERT operation |
Request Headers
| Header | Required | Description |
Authorization | Yes | Your Personal Access Token (PAT) from platform.peak.ai |
Content-Type | Yes | Must be application/json |
Properties
Primary Keys
- product_id (string) - Unique identifier for the product
- updated_at (datetime) - Timestamp of when the record was last updated
Attributes
About Required + Nullable: every attribute key must appear in each payload (Required: Yes). Nullable: Yes means the value can be null when you don't have data; Nullable: No means a non-null value is required. See Schema definition structure for the underlying rules.
| Attribute | Data Type | Required | Nullable | Description |
product_id | string | Yes | No | Unique identifier for each product. Used to join product metadata to quotations and sales for model training. |
updated_at | datetime | Yes | Yes | Timestamp when the record was updated. Used to identify the most up-to-date data in the UI and to match product metadata to the date of each quote in model training. |
product_name | string | Yes | No | Product name. Used in the UI to identify products. |
bespoke_product | boolean | Yes | Yes | Whether the product is bespoke (custom-made) or standard. Used in model training as a feature to determine the optimal quote price. |
product_category | string | Yes | Yes | Product category. Used in model training as a feature to determine the optimal quote price. |
product_subcategory | string | Yes | Yes | Product sub-category. Used in model training as a feature to determine the optimal quote price. |
Relationships
Outbound References
This resource has relationships to:
- competitor_price - Products can have competitive pricing data
- list_price - Products can have list prices across regions
- product_cost - Products can have cost information
- quote_line - Products can appear in quote line items
- sale - Products can be sold
Inbound References
None
JSON Representation
"solutionName": "QP_OOTB",
"data": [
"product_id": "PROD-001",
"updated_at": "2025-01-28T10:00:00Z",
"product_name": "Premium Widget",
"bespoke_product": false,
"product_category": "Electronics",
"product_subcategory": "Components"
"operationType": "UPSERT"
"data": [
Example Request
curl -X POST \
'https://ingestion.peak.ai/api/v2/objects/QP_PRODUCT_OOTB' \
-d '{
"data": [
curl -X POST \
-d '{
"data": [
Important Notes
- Bespoke Products: The
bespoke_productflag can be used to identify custom or made-to-order products - Custom Attributes: Custom attributes can be added with
POST /api/v2/schema/{objectName}/add-attribute, where{objectName}is this table's fully qualified warehouse name ({prefix}PRODUCT{suffix}— for example,QP_PRODUCT_OOTB), as returned by Describe a solution's schema - Data Validation: All attributes are validated according to their defined data types
Related Resources
- competitor_price - Competitor pricing for products
- list_price - List pricing for products
- product_cost - Cost information for products
- quote_line - Quote line items referencing products
- sale - Sales records for products
- region - Geographic regions for pricing
