industry-department-solutions
此内容在所选语言中不可用。系统会改为显示英文内容。
Purchase Order
purchase_order API resource representing purchase orders per product-location combination, tracking order details, delivery status, and fulfillment.
Overview​
The purchase_order resource represents purchase orders for products at specific locations. This resource tracks order details, delivery status, and fulfillment information.
Resource Endpoint​
/api/v2/ingest/object/{prefix}PURCHASE_ORDER{suffix}
Supported Methods​
MethodReturn TypeDescription
POSTResponseIngest (create/update) purchase order records via UPSERT operation
Request Headers​
HeaderRequiredDescription
AuthorizationYesYour Personal Access Token (PAT) from platform.peak.ai
Content-TypeYesMust be application/json
Properties​
Primary Keys​
  • order_number (string) - Unique order identifier
  • product_id (string) - Foreign key reference to products
Attributes​
About Required + Nullable: every attribute key must appear in each payload (Required: Yes). Nullable: Yes means the value can be null when you don't have data; Nullable: No means a non-null value is required. See Schema definition structure for the underlying rules.
AttributeData TypeRequiredNullableDescription
order_numberstringYesNoUnique order number (Primary Key)
product_idstringYesNoProduct identifier (Primary Key, Foreign Key)
location_idstringYesNoLocation identifier (Foreign Key)
order_due_date_attimestampYesNoWhen the order is due to be delivered
ordered_attimestampYesNoWhen the order was placed
ordered_unitsintegerYesNoNumber of units ordered
purchase_order_idstringYesYesAlternative purchase order identifier
statusstringYesYesCurrent status of the order
delivered_unitsintegerYesYesNumber of units delivered
receipted_unitsintegerYesYesNumber of units receipted/confirmed
receipt_datedateYesYesDate when goods were receipted
actual_departure_attimestampYesYesActual departure timestamp
expected_departure_attimestampYesYesExpected departure timestamp
created_attimestampYesYesTimestamp when the record was created
updated_attimestampYesYesTimestamp when the record was last updated
Relationships​
Outbound References​
None
Inbound References​
  • product - Foreign key product_id references product
  • location - Foreign key location_id references location
JSON Representation​
  "solutionName": "MP_OOTB",
  "data": [
      "order_number": "PO-2025-001",
      "product_id": "PROD-001",
      "location_id": "LOC-UK-001",
      "order_due_date_at": "2025-02-15T00:00:00Z",
      "ordered_at": "2025-01-20T10:30:00Z",
      "ordered_units": 500,
      "purchase_order_id": "PO-2025-001",
      "status": "In Transit",
      "delivered_units": 0,
      "receipted_units": 0,
      "receipt_date": null,
      "actual_departure_at": "2025-01-22T08:00:00Z",
      "expected_departure_at": "2025-01-21T08:00:00Z",
      "created_at": "2025-01-20T10:30:00Z",
      "updated_at": "2025-01-28T10:00:00Z"
  "operationType": "UPSERT"
  "data": [
Example Request​
curl -X POST \
  'https://ingestion.peak.ai/api/v2/objects/MP_PURCHASE_ORDER_OOTB' \
  -d '{
    "data": [
curl -X POST \
  -d '{
    "data": [
Important Notes​
  • Foreign Key Dependencies: Can reference products and locations
  • Order Tracking: Tracks the full lifecycle from order placement to receipt
  • Fulfillment Status: Monitor ordered vs delivered vs receipted units
  • Departure Tracking: Captures both expected and actual departure times
  • Custom Attributes: Additional custom attributes can be added using the /PURCHASE_ORDER/add-attribute endpoint
  • Data Validation: All attributes are validated according to their defined data types
  • product - Product information
  • location - Delivery location
  • stock - Stock levels affected by purchase orders
此页面有帮助吗?
连接
需要帮助? 支持
想要了解详细内容? UiPath Academy
有问题? UiPath 论坛
保持更新
