industry-department-solutions
- Overview
- API Resources
此内容在所选语言中不可用。系统会改为显示英文内容。
Product Category
product_category API resource representing product categories in the B2C pricing application, with parent-child hierarchical structure support.
The product_category resource represents product categories in the B2C pricing application. This resource supports hierarchical category structures with parent-child relationships.
Resource Endpoint
/api/v2/ingest/object/{prefix}PRODUCT_CATEGORY{suffix}
Supported Methods
| Method | Return Type | Description |
| POST | Response | Ingest (create/update) product category records via UPSERT operation |
Request Headers
| Header | Required | Description |
Authorization | Yes | Your Personal Access Token (PAT) from platform.peak.ai |
Content-Type | Yes | Must be application/json |
Properties
Primary Keys
- product_category_id (string) - Unique identifier for the product category
Attributes
About Required + Nullable: every attribute key must appear in each payload (Required: Yes). Nullable: Yes means the value can be null when you don't have data; Nullable: No means a non-null value is required. See Schema definition structure for the underlying rules.
| Attribute | Data Type | Required | Nullable | Description |
product_category_id | string | Yes | No | Unique product category identifier (Primary Key) |
name | string | Yes | Yes | Display name of the category |
metadata | string | Yes | Yes | Additional metadata or attributes in JSON format |
parent_product_category_id | string | Yes | Yes | Reference to the parent category, for hierarchical structure |
created_at | timestamp | Yes | Yes | Timestamp when the record was created |
updated_at | timestamp | Yes | Yes | Timestamp when the record was last updated |
Relationships
Outbound References
This resource has relationships to:
- product - Categories can contain multiple products
- product_category (self-reference) - Categories can have child categories
Inbound References
parent_product_category_idpoints to a parent category to form hierarchies — a logical reference, not an enforced foreign key
JSON Representation
"solutionName": "MP_OOTB",
"data": [
"product_category_id": "CAT-ELEC",
"name": "Electronics",
"metadata": "{\"display_order\": 1, \"is_featured\": true}",
"parent_product_category_id": null,
"created_at": "2025-01-10T08:00:00Z",
"updated_at": "2025-01-28T10:00:00Z"
"operationType": "UPSERT"
"data": [
Example Request
curl -X POST \
'https://ingestion.peak.ai/api/v2/objects/MP_PRODUCT_CATEGORY_OOTB' \
-d '{
"data": [
curl -X POST \
-d '{
"data": [
Important Notes
- Primary Key: This resource uses
product_category_idas the primary key - Hierarchical Structure: The
parent_product_category_idenables multi-level category trees - Self-Referencing: Categories can reference other categories as parents
- Flexible Metadata: The
metadatafield allows storing additional structured information - Custom Attributes: Additional custom attributes can be added using the
/PRODUCT_CATEGORY/add-attributeendpoint - Data Validation: All attributes are validated according to their defined data types
Related Resources
- product - Products belonging to categories
- product_category - Parent/child category relationships
