- 概述
- 要求
- 预安装
- 安装
- 安装后
- 迁移和升级
- 监控和警示
- 集群管理
- 特定于产品的配置
- 故障排除
配置 Automation Suite Robot 失败
上次更新日期 2024年12月18日
将 Azure 文件与 NFS 协议一起使用时,故障主要发生在已启用 FIPS 的节点上。
在 AKS 上安装 Automation Suite 期间,为 Automation Suite Robot
asrobots-pvc-package-cache
创建 PVC 失败。
发生这种情况是因为 AKS 集群无法连接到 Azure 文件。
例如,可能会显示以下错误消息:
failed to provision volume with StorageClass "azurefile-csi-nfs": rpc error: code = Internal desc = update service endpoints failed with error: failed to get the subnet ci-asaks4421698 under vnet ci-asaks4421698: &{false 403 0001-01-01 00:00:00 +0000 UTC {"error":{"code":"AuthorizationFailed","message":"The client '4c200854-2a79-4893-9432-3111795beea0' with object id '4c200854-2a79-4893-9432-3111795beea0' does not have authorization to perform action 'Microsoft.Network/virtualNetworks/subnets/read' over scope '/subscriptions/64fdac10-935b-40e6-bf28-f7dc093f7f76/resourceGroups/ci-asaks4421698/providers/Microsoft.Network/virtualNetworks/ci-asaks4421698/subnets/ci-asaks4421698' or the scope is invalid. If access was recently granted, please refresh your credentials."}}}
