Linux 版 Automation Suite 安装指南
为 Process Mining 设置具有基本 MSSQL 身份验证的 Kerberos 身份验证
备注:
When you are performing a new installation and you want to use Kerberos authentication, it is strongly recommended to configure process app security as single_account. Refer to Configuring process app security for details.
如果您要使用 Kerberos 身份验证登录 Automation Suite,将对基本 MSSQL 身份验证用于 Process Mining,则需要在 cluster_config.json 文件的 processmining 部分中添加以下内容。
"kerberos_auth_config": {
      "enabled": false
      "enabled": false
以下代码显示了一个 processmining 部分的示例,其中包含适用于 Process Mining 的 Kerberos 身份验证和基本 MSSQL 身份验证。
 "processmining": {
    "enabled": true,
      "enabled": false
    "sql_connection_str": "Server=tcp:servername.database.windows.net,1433;Initial Catalog=AutomationSuite_ProcessMining_Metadata;Persist Security Info=False;User ID=username;Password=Password@password;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;",
    "sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://username%servername.database.windows.net:password%password@servername.database.windows.net:1433/AutomationSuite_Airflow?driver=ODBC+Driver+17+for+SQL+Server",
    "warehouse": {
          "sql_connection_str": "Server=tcp:servername.database.windows.net,1433;Initial Catalog=AutomationSuite_ProcessMining_Warehouse;Persist Security Info=False;User ID=username;Password=Password@password;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;",
          "sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://username%servername.database.windows.net:Password%password@servername.database.windows.net:1433/AutomationSuite_ProcessMining_Warehouse?driver=ODBC+Driver+17+for+SQL+Server"
 "processmining": {
    "enabled": true,
      "enabled": false
    "warehouse": {
此页面有帮助吗?
连接
需要帮助? 支持(opens in new window)
保持更新
