- 概述
- 要求
- 安装
- 先决条件检查
- 下载安装包
- uipathctl cluster
- uipathctl 集群维护
- uipathctl 集群升级
- uipathctl 配置
- uipathctl 配置警示
- uipathctl configalerts add-email
- uipathctl 运行状况
- uipathctl 运行状况捆绑包
- uipathctl 运行状况检查
- uipathctl health diagnose
- uipathctl health test
- uipathctl identity
- uipathctl identity add-host-admin
- uipathctl identity Enable-basic-auth
- uipathctl 清单
- uipathctl manifest apply
- uipathctl manifest diff
- uipathctl manifest get
- uipathctl manifest render
- uipathctl 先决条件
- uipathctl prereq create
- uipathctl prereq run
- uipathctl 资源
- uipathctl 资源报告
- uipathctl 快照
- uipathctl 快照备份
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- uipathctl sso
- uipathctl sso generate-connector
- uipathctl sso generate-overlays
- uipathctl sso generate-rbac
- uipathctl 版本
- 安装后
- 迁移和升级
- 监控和警示
- 集群管理
- 特定于产品的配置
- 故障排除
uipathctl identity
请注意此内容已使用机器翻译进行了部分本地化。
Last updated 2024年11月1日
uipathctl identity
