AKS input.json 示例
以下示例显示了启用了 AKS 上所有产品的input.json文件,以及 AKS 上 Automation Suite 的必需配置参数和可选配置参数。您可以将该示例用作参考,并根据环境要求进行更改。
请注意,UiPath™ 产品选择至少要求启用平台服务。 确保将 FQDN、主机名、用户名和密码以及 SQL 连接字符串替换为您自己的配置。
  "registries": {
    "docker": {
      "url": "registry.uipath.com"
    "helm": {
  "fqdn": "ci-asaks4002399.devtest-sl-ea.infra.uipath-dev.com",
  "profile": "ha",
  "fabric": {
    "redis": {
      "hostname": "ci-asaks4002399.redis.cache.windows.net",
      "password": "REDIS_PASSWORD_PLACEHOLDER",
      "port": 6380,
      "tls": true
  "external_object_storage": {
    "enabled": true,
    "storage_type": "azure",
    "account_key": "----",
    "account_name": "----",
    "bucket_name_prefix": "",
    "bucket_name_suffix": "",
    "azure_fqdn_suffix": "core.windows.net",
    "use_managed_identity": false
  "kubernetes_distribution": "aks",
  "sql_connection_string_template": "Server=tcp:ci-asaks4002399.database.windows.net,1433;Initial Catalog=DB_NAME_PLACEHOLDER;Persist Security Info=False;User Id=mssqladminun@ci-asaks4002399.database.windows.net;Password='SQL_PASSWORD_PLACEHOLDER';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;",
  "sql_connection_string_template_jdbc": "jdbc:sqlserver://ci-asaks4002399.database.windows.net;database=DB_NAME_PLACEHOLDER;user=mssqladminun@ci-asaks4002399.database.windows.net;password={SQL_PASSWORD_PLACEHOLDER};encrypt=true;trustServerCertificate=false;hostNameInCertificate=*.database.windows.net;loginTimeout=30;",
  "sql_connection_string_template_odbc": "SERVER=ci-asaks4002399.database.windows.net;DATABASE=DB_NAME_PLACEHOLDER;DRIVER={ODBC Driver 17 for SQL Server};UID=mssqladminun;PWD={SQL_PASSWORD_PLACEHOLDER};Encrypt=yes;TrustServerCertificate=no;Connection Timeout=30;hostNameInCertificate=ci-asaks4002399.database.windows.net",
  "sql_connection_string_template_sqlalchemy_pyodbc": "mssql+pyodbc://mssqladminun%40ci-asaks4002399.database.windows.net:SQL_PASSWORD_PLACEHOLDER@ci-asaks4002399.database.windows.net:1433/DB_NAME_PLACEHOLDER?driver=ODBC+Driver+17+for+SQL+Server&TrustServerCertificate=no&Encrypt=yes",
  "admin_username": "admin",
  "admin_password": "----",
  "dataservice": {
    "enabled": true,
      "bucket_name": "uipath-as-dataservice"
  "orchestrator": {
    "enabled": true,
      "bucket_name": "uipath-as-orchestrator"
    "testautomation": {
      "enabled": true
    "updateserver": {
      "enabled": true
  "processmining": {
      "bucket_name": "uipath-as-processmining"
    "enabled": true
  "insights": {
    "enabled": true,
      "bucket_name": "uipath-as-platform"
  "task_mining": {
      "bucket_name": "uipath-as-taskmining"
    "enabled": true
  "automation_hub": {
    "enabled": true,
  "automation_ops": {
    "enabled": true,
  "aicenter": {
    "enabled": true
  "documentunderstanding": {
    "enabled": true
  "test_manager": {
    "enabled": true,
  "action_center": {
    "enabled": true,
  "apps": {
    "enabled": true,
  "asrobots": {
    "packagecaching": true,
    "packagecachefolder": "/uipath_asrobots_package_cache",
    "enabled": true
  "storage_class": "managed-premium",
  "storage_class_single_replica": "azurefile-csi",
  "infra": {
    "docker_registry": {}
  "ingress": {
    "service_annotations": {
      "service.beta.kubernetes.io/azure-load-balancer-internal": "true"
  "snapshot": {
    "enabled": true,
    "aks_infra_resource_group": "MC_ci-asaks4002399_ci-asaks4002399_eastus",
      "cloud_name": "AzurePublicCloud",
      "resource_group": "ci-asaks4002399",
      "auth_mode": "ServicePrincipal",
      "subscription_id": "b65b0225-ce9b-4a79-9dd9-c00071d40d64",
      "tenant_id": "d8353d2a-b153-4d17-8827-902c51f72357",
      "account_name": "storaccid2547865",
      "bucket_name": "uipath-backup",
      "client_id": "1fbd7d95-5f8c-4f70-90a6-fdf20310d10e",
      "client_secret": "----"
  "platform": {
    "enabled": true
  "registries": {
    "docker": {
    "helm": {
  "profile": "ha",
  "fabric": {
    "redis": {
      "port": 6380,
      "tls": true
    "enabled": true,
  "dataservice": {
    "enabled": true,
  "orchestrator": {
    "enabled": true,
    "testautomation": {
      "enabled": true
    "updateserver": {
      "enabled": true
  "processmining": {
    "enabled": true
  "insights": {
    "enabled": true,
  "task_mining": {
    "enabled": true
  "automation_hub": {
    "enabled": true,
  "automation_ops": {
    "enabled": true,
  "aicenter": {
    "enabled": true
    "enabled": true
  "test_manager": {
    "enabled": true,
  "action_center": {
    "enabled": true,
  "apps": {
    "enabled": true,
  "asrobots": {
    "enabled": true
  "infra": {
  "ingress": {
  "snapshot": {
    "enabled": true,
  "platform": {
    "enabled": true
此页面有帮助吗?
连接
需要帮助? 支持
想要了解详细内容? UiPath Academy
有问题? UiPath 论坛
保持更新
