OpenShift 上的 Automation Suite 安装指南
请注意,此内容已使用机器翻译进行了部分本地化。
新发布内容的本地化可能需要 1-2 周的时间才能完成。
重新映射组织 ID
从独立版 Insights 迁移到 Automation Suite 时重新映射组织 ID。
要从独立版 Insights 迁移到 Automation Suite,您必须重新映射以下表格中的组织 ID:
[Id] [int] NOT NULL,
[Key] [nvarchar](128) NOT NULL,
[Name] [nvarchar](128) NOT NULL,
[IsActive] [bit] NOT NULL,
[IsDeleted] [bit] NOT NULL,
[OrganizationId] [nvarchar](128) NULL,
CONSTRAINT [PK_dbo.Tenants] PRIMARY KEY CLUSTERED
CREATE TABLE [insightsintegrations].[TenantServiceIntegrations](
[Id] [uniqueidentifier] NOT NULL,
[TenantId] [uniqueidentifier] NOT NULL,
[OrganizationId] [uniqueidentifier] NOT NULL,
[ServiceName] [int] NOT NULL,
[Status] [int] NOT NULL,
[CreationTime] [datetime2](7) NOT NULL,
[LastUpdatetime] [datetime2](7) NOT NULL,
CONSTRAINT [PK_TenantServiceIntegrations] PRIMARY KEY CLUSTERED
CREATE TABLE [insightspermissions].[GroupRoles](
[GroupId] [uniqueidentifier] NOT NULL,
[RoleId] [uniqueidentifier] NOT NULL,
CONSTRAINT [PK_GroupRoles] PRIMARY KEY CLUSTERED
CREATE TABLE [insightspermissions].[Groups](
[Name] [nvarchar](max) NULL,
[Email] [nvarchar](max) NULL,
CONSTRAINT [PK_Groups] PRIMARY KEY CLUSTERED
CREATE TABLE [insightspermissions].[Roles](
[TenantId] [uniqueidentifier] NULL,
[Resource] [nvarchar](max) NULL,
CONSTRAINT [PK_Roles] PRIMARY KEY CLUSTERED
CREATE TABLE [insightspermissions].[TenantGroups](
[TimeProcessed] [datetime2](7) NULL,
[LastUpdateTime] [datetime2](7) NOT NULL,
CONSTRAINT [PK_TenantGroup] PRIMARY KEY CLUSTERED
CREATE TABLE [insightspermissions].[Tenants](
CONSTRAINT [PK_Tenants] PRIMARY KEY CLUSTERED
CREATE TABLE [insightspermissions].[Users](
[IsDeleted] [bit] NULL,
CONSTRAINT [PK_Users] PRIMARY KEY CLUSTERED
CREATE TABLE [insightsprovisioning].[TenantInstances](
[ServiceType] [nvarchar](max) NULL,
[State] [int] NOT NULL,
[TenantName] [nvarchar](max) NULL,
CONSTRAINT [PK_TenantInstances] PRIMARY KEY CLUSTERED
CREATE TABLE [read].[HASHKEYS](
[hashkey] [bigint] NOT NULL,
[tenantkey] [nvarchar](128) NOT NULL,
[tenantname] [nvarchar](256) NULL,
[organizationid] [nvarchar](128) NULL,
[status] [int] NULL
[status] [int] NULL
[dbo].[Tenants]
[read].[HASHKEYS]
[dbo].[Tenants]
[read].[HASHKEYS]
提示:
这是有关如何更新表格的示例:
--- Script to replace MSI organization ID with AS organization ID.
--- Please update the following DECLARE statements with your corresponding MSI org ID and AS org ID before executing this script.
DECLARE @msi_organization_id nvarchar(500) = upper('687db434-ce5c-4058-bc0b-3ed3fa23882b');
DECLARE @as_organization_id nvarchar(500) = upper('AA259F1A-5828-4608-AF71-27177A7831B8');
DECLARE @msi_resource nvarchar(500) = lower('insights/687db434-ce5c-4058-bc0b-3ed3fa23882b/687db434-ce5c-4058-bc0b-3ed3fa23882b/*');
DECLARE @as_resource nvarchar(500) = lower('insights/aa259f1a-5828-4608-af71-27177a7831b8/687db434-ce5c-4058-bc0b-3ed3fa23882b/*');
SELECT * FROM [dbo].[Tenants];
UPDATE [dbo].[Tenants]
SET OrganizationId = lower(@as_organization_id)
WHERE OrganizationId = lower(@msi_organization_id);
SELECT * FROM [insightsintegrations].[TenantServiceIntegrations];
UPDATE [insightsintegrations].[TenantServiceIntegrations]
SET OrganizationId = @as_organization_id
WHERE OrganizationId = @msi_organization_id;
ALTER TABLE [insightspermissions].[GroupRoles] NOCHECK CONSTRAINT FK_GroupRoles_Groups_GroupId_OrganizationId;
SELECT * FROM [insightspermissions].[GroupRoles];
UPDATE [insightspermissions].[GroupRoles]
ALTER TABLE [insightspermissions].[GroupRoles] CHECK CONSTRAINT FK_GroupRoles_Groups_GroupId_OrganizationId;
ALTER TABLE [insightspermissions].[TenantGroups] NOCHECK CONSTRAINT FK_TenantGroups_Groups_GroupId_OrganizationId;
SELECT * FROM [insightspermissions].[TenantGroups];
UPDATE [insightspermissions].[TenantGroups]
ALTER TABLE [insightspermissions].[TenantGroups] CHECK CONSTRAINT FK_TenantGroups_Groups_GroupId_OrganizationId;
SELECT * FROM [insightspermissions].[Groups];
UPDATE [insightspermissions].[Groups]
SELECT * FROM [insightspermissions].[Roles];
UPDATE [insightspermissions].[Roles]
SET Resource = @as_resource
WHERE Resource = @msi_resource;
SELECT * FROM [insightspermissions].[Tenants];
UPDATE [insightspermissions].[Tenants]
SELECT * FROM [insightspermissions].[Users];
UPDATE [insightspermissions].[Users]
SELECT * FROM [insightsprovisioning].[TenantInstances];
UPDATE [insightsprovisioning].[TenantInstances]
SELECT * FROM [read].[HASHKEYS];
UPDATE [read].[HASHKEYS]
