OpenShift 上的 Automation Suite 安装指南
请注意,此内容已使用机器翻译进行了部分本地化。
新发布内容的本地化可能需要 1-2 周的时间才能完成。
输出示例:先决条件检查
OpenShift 上 Automation Suite 中的先决条件检查的输出示例。
以下示例显示了在检查 Automation Suite 安装过程中的基础架构先决条件后可能获得的输出。有关详细信息,请参阅先决条件检查。
ℹ️ [empty-app] Creating Argo CD application for component empty-app...
ℹ️ [empty-app] Waiting for Argo CD application for component empty-app to synchronize...
Ran cluster/ checks...
Ran ORCHESTRATOR(CLASSIC_FOLDERS) checks...
✔ successful
Ran local/ checks...
Ran ARGO checks...
✔ successful
Ran CONNECTIVITY checks...
✔ successful
Ran DEPLOYMENT_PROFILE checks...
✔ successful
Ran DNS(FQDN=APPS.<FQDN>) checks...
✔ successful
Ran DNS(FQDN=INSIGHTS.<FQDN>) checks...
✔ successful
Ran INGRESS checks...
⚠ [INGRESS]
⚠ [UIPATH_GATEWAY_NOT_FOUND] Istio service found but gateway main-gateway not found in uipath namespace
Ran NAMESPACE checks...
✔ successful
Ran NETWORK-POLICIES checks...
✔ successful
Ran NODE(CPU >= 8, RAM >= 16G) checks...
⚠ [NODE(CPU >= 8, RAM >= 16G)]
✔ [LIST_NODES] Listed 4 nodes
✔ [AT_LEAST_ONE_NODE] At least one node found
✔ [CPU_USAGE] Node os7140768-7db2g-master-0 has 37.50% CPU usage
✔ [MEMORY_USAGE] Node os7140768-7db2g-master-0 has 46.35% memory usage
✔ [POD_USAGE] Node os7140768-7db2g-master-0 has 0.00% of pods in use. Number of pods: 0.00 max allowed: 250.00
✔ [CPU_CAPACITY(os7140768-7db2g-master-0)] Node has enough CPU capacity. Has: 8, needs at least: 8
✔ [RAM_CAPACITY(os7140768-7db2g-master-0)] Node has enough RAM capacity. Has: 32868564Ki, needs at least: 16G
✔ [CPU_USAGE] Node os7140768-7db2g-worker-eastus1-l6c5p has 12.50% CPU usage
✔ [MEMORY_USAGE] Node os7140768-7db2g-worker-eastus1-l6c5p has 13.64% memory usage
✔ [POD_USAGE] Node os7140768-7db2g-worker-eastus1-l6c5p has 0.40% of pods in use. Number of pods: 1.00 max allowed: 250.00
✔ [CPU_CAPACITY(os7140768-7db2g-worker-eastus1-l6c5p)] Node has enough CPU capacity. Has: 16, needs at least: 8
✔ [RAM_CAPACITY(os7140768-7db2g-worker-eastus1-l6c5p)] Node has enough RAM capacity. Has: 65847764Ki, needs at least: 16G
✔ [CPU_USAGE] Node os7140768-7db2g-worker-eastus2-p89lq has 6.25% CPU usage
✔ [MEMORY_USAGE] Node os7140768-7db2g-worker-eastus2-p89lq has 8.30% memory usage
✔ [POD_USAGE] Node os7140768-7db2g-worker-eastus2-p89lq has 0.40% of pods in use. Number of pods: 1.00 max allowed: 250.00
✔ [CPU_CAPACITY(os7140768-7db2g-worker-eastus2-p89lq)] Node has enough CPU capacity. Has: 16, needs at least: 8
✔ [RAM_CAPACITY(os7140768-7db2g-worker-eastus2-p89lq)] Node has enough RAM capacity. Has: 65847764Ki, needs at least: 16G
✔ [CPU_USAGE] Node os7140768-7db2g-worker-eastus3-d6jj5 has 18.75% CPU usage
✔ [MEMORY_USAGE] Node os7140768-7db2g-worker-eastus3-d6jj5 has 11.11% memory usage
✔ [POD_USAGE] Node os7140768-7db2g-worker-eastus3-d6jj5 has 0.80% of pods in use. Number of pods: 2.00 max allowed: 250.00
✔ [CPU_CAPACITY(os7140768-7db2g-worker-eastus3-d6jj5)] Node has enough CPU capacity. Has: 16, needs at least: 8
✔ [RAM_CAPACITY(os7140768-7db2g-worker-eastus3-d6jj5)] Node has enough RAM capacity. Has: 65847764Ki, needs at least: 16G
⚠ [AS_ROBOTS_NODE_EXISTS] No dedicated node found
Ran OSS(COMPONENT=CERT-MANAGER) checks...
✔ successful
Ran OSS(COMPONENT=GATEKEEPER) checks...
✔ successful
Ran OSS(COMPONENT=ISTIO) checks...
✔ successful
Ran PERMISSION checks...
✔ successful
Ran PRIORITYCLASS checks...
✔ successful
Ran REGISTRY_PULL checks...
✔ successful
Ran RESOURCE checks...
✔ successful
Ran SECRETS checks...
✔ successful
Ran STORAGECLASS(NAME=STORAGE_CLASS) checks...
✔ successful
Ran STORAGECLASS(NAME=STORAGE_CLASS_SINGLE_REPLICA) checks...
✔ successful
Ran nodes/ checks...
Ran CONTROLPLANECONNECTIVITY checks...
✔ 4/4 nodes successful
Ran OBJECTSTORAGE(PRODUCT=BA) checks...
Ran OBJECTSTORAGE(PRODUCT=DATASERVICE) checks...
Ran OBJECTSTORAGE(PRODUCT=ORCHESTRATOR) checks...
Ran OBJECTSTORAGE(PRODUCT=PLATFORM) checks...
Ran OBJECTSTORAGE(PRODUCT=TESTMANAGER) checks...
Ran REDIS(PORT=6380) checks...
Ran SQL(PRODUCT=ASROBOTS, TYPE=ADO) checks...
Ran SQL(PRODUCT=AUTOMATIONHUB, TYPE=ADO) checks...
Ran SQL(PRODUCT=AUTOMATIONOPS, TYPE=ADO) checks...
Ran SQL(PRODUCT=BA, TYPE=ODBC) checks...
Ran SQL(PRODUCT=DATASERVICE, TYPE=ADO) checks...
Ran SQL(PRODUCT=INSIGHTS, TYPE=ADO) checks...
Ran SQL(PRODUCT=NOTIFICATIONSERVICE, TYPE=ADO) checks...
Ran SQL(PRODUCT=ORCHESTRATOR, TYPE=ADO) checks...
Ran SQL(PRODUCT=PLATFORM, TYPE=ADO) checks...
Ran SQL(PRODUCT=TESTMANAGER, TYPE=ADO) checks...
Checks complete!
✔ successful
Ran ARGO checks...
✔ successful
✔ successful
✔ successful
✔ successful
✔ successful
⚠ [INGRESS]
✔ successful
✔ successful
✔ successful
✔ successful
✔ successful
✔ successful
✔ successful
✔ successful
✔ successful
✔ successful
✔ successful
✔ successful
Checks complete!
