OpenShift 上的 Automation Suite 安装指南
为 ODF 4.20 配置 CSI 驱动程序容错
在 Automation Suite 中为 OpenShift Data Foundation 4.20 配置 Ceph CSV 驱动程序容错。
描述​
OpenShift Data Foundation (ODF) 4.20 使用 rook 1.18,该 rook 将 Ceph CSI 驱动程序提取到单独的运算符中。因此,先前通过CSI_PLUGIN_TOLERATIONS配置映射传递容错的方法不再有效。要确保将 Ceph CSI 节点插件计划在正确的节点上,您必须向 Ceph CSI 节点插件显式添加容忍。
解决方案​
成功部署存储集群后,请执行以下步骤:
  1. 将以下配置保存到 YAML 文件中:
    apiVersion: csi.ceph.io/v1
    kind: Driver
    metadata:
      namespace: openshift-storage
    spec:
      nodePlugin:
        tolerations:
        - effect: NoSchedule
          key: node.ocs.openshift.io/storage
          operator: Equal
          value: "true"
          key: serverless.robot
          operator: Equal
          value: "present"
          key: node-role.kubernetes.io/control-plane
          operator: Exists
          key: uipath
          operator: Exists
    kind: Driver
    metadata:
    spec:
      nodePlugin:
        tolerations:
          operator: Equal
          value: "true"
          operator: Equal
          value: "present"
          operator: Exists
          key: uipath
          operator: Exists
    kind: Driver
    metadata:
    spec:
      nodePlugin:
        tolerations:
          operator: Equal
          value: "true"
          operator: Equal
          value: "present"
          operator: Exists
          key: uipath
          operator: Exists
    kind: Driver
    metadata:
    spec:
      nodePlugin:
        tolerations:
          operator: Equal
          value: "true"
          operator: Equal
          value: "present"
          operator: Exists
          key: uipath
          operator: Exists
  2. 通过运行以下命令应用配置:
    oc apply -f <filename>.yaml
  • 描述​
  • 解决方案​
此页面有帮助吗?
连接
需要帮助? 支持
想要了解详细内容? UiPath Academy
有问题? UiPath 论坛
保持更新
