- 概述
- 要求
- 预安装
- 安装
- 安装后
- 迁移和升级
- 监控和警示
- 集群管理
- 特定于产品的配置
- 故障排除
- 由于无法连接到 Azure Government,备份设置不起作用
- 启用自定义节点污点时,UiPath 命名空间中的 Pod 卡住
- 无法使用代理设置启动 Automation Hub 和 Apps
- 由于“验证失败”错误,Velero 备份失败
- 外部密码故障排除
- 时间即服务故障排除
- TLS 证书验证错误
- Fluentd 不会在 IPv6 环境中导出日志
请注意,此内容已使用机器翻译进行了部分本地化。
新发布内容的本地化可能需要 1-2 周的时间才能完成。
输出示例:先决条件检查
EKS/AKS 的先决条件验证检查输出示例。
以下示例显示了在准备安装 Automation Suite 时检查基础架构先决条件后可能获得的输出。有关详细信息,请参阅检查基础架构先决条件。
Checks run on nodes/aks-pool1-27380386-vmss000000
✔ [SQL(PRODUCT=TEST_MANAGER, TYPE=ADO)]
✔ [EXECUTE_NATIVE] Successfully executed command
✔ [BUILD_CLIENT] Successfully built ADO client
✔ [CONNECT] Successfully connected ADO client to DB
✔ [DB_ROLES] SQL user has the required roles to DB
✔ [DNS(FQDN=INSIGHTS.<FQDN>)]
✔ [VALIDATE_FQDN] FQDN is valid
✔ [RESOLVE_TOP_DOMAIN] Resolved http://ci-asaks3955328.devtest-ascloudgen-ea.infra.uipath-dev.com to [{20.9.49.161 }]
✔ [RESOLVE_SUBDOMAIN] Resolved insights.ci-asaks3955328.devtest-ascloudgen-ea.infra.uipath-dev.com to [{20.9.49.161 }]
✔ [IPS_MATCH] Subdomain resolves to top domain
✔ [SQL(PRODUCT=ASROBOTS, TYPE=ADO)]
✔ [SQL(PRODUCT=ORCHESTRATOR, TYPE=ADO)]
✔ [OBJECTSTORAGE(PRODUCT=APPS)]
✔ [CHECK_API] Object storage test passed for apps
✔ [OBJECTSTORAGE(PRODUCT=TEST_MANAGER)]
✔ [CHECK_API] Object storage test passed for test_manager
✔ [OBJECTSTORAGE(PRODUCT=PLATFORM)]
✔ [CHECK_API] Object storage test passed for platform
✔ [REDIS(PORT=6380)]
✔ [CONNECTIVITY] Successfully made Redis connection on ci-asaks3955328.redis.cache.windows.net:6380
✔ [SQL(PRODUCT=AUTOMATION_OPS, TYPE=ADO)]
✔ [SQL(PRODUCT=AUTOMATION_HUB, TYPE=ADO)]
✔ [COMPATIBILITY_LEVEL] SQL DB compatibility level meets requirement
✔ [SQL(PRODUCT=INSIGHTS, TYPE=ADO)]
✔ [COLUMNSTORE_INDEX] Columnstore index is supported for SQL DB
✔ [OPENJSON] OpenJSON is supported for SQL DB
✔ [OBJECTSTORAGE(PRODUCT=ORCHESTRATOR)]
✔ [CHECK_API] Object storage test passed for orchestrator
✔ [SQL(PRODUCT=DATASERVICE, TYPE=ADO)]
✔ [SQL(PRODUCT=APPS, TYPE=ODBC)]
✔ [BUILD_CLIENT] Successfully built ODBC client
✔ [CONNECT] Successfully connected ODBC client to DB
✔ [SQL(PRODUCT=PLATFORM, TYPE=ADO)]
✔ [OBJECTSTORAGE(PRODUCT=DATASERVICE)]
✔ [CHECK_API] Object storage test passed for dataservice
✔ [DNS(FQDN=MONITORING.<FQDN>)]
✔ [RESOLVE_SUBDOMAIN] Resolved http://monitoring.ci-asaks3955328.devtest-ascloudgen-ea.infra.uipath-dev.com to [{20.9.49.161 }]
✔ [DNS(FQDN=ALM.<FQDN>)]
✔ [RESOLVE_SUBDOMAIN] Resolved http://alm.ci-asaks3955328.devtest-ascloudgen-ea.infra.uipath-dev.com to [{20.9.49.161 }]
Checks run on nodes/aks-pool0-27380386-vmss000000
Checks run on nodes/aks-pool0-27380386-vmss000003
Checks run on nodes/aks-pool0-27380386-vmss000004
Checks run on nodes/aks-pool0-27380386-vmss000001
Checks run on nodes/aks-pool0-27380386-vmss000002
Checks run on local/
✔ [STORAGECLASS(NAME=STORAGE_CLASS)]
✔ [STORAGE_CLASS_EXISTS] Storage class managed-premium exists
✔ [LIST_NODES] Listed 6 nodes
✔ [CREATE_NAMESPACE] Created namespace prereq6g5cg
✔ [CREATE_STATEFULSET] Created statefulset storage-class-check-wthrk
✔ [LIST_PODS] Listed 1 pods on node aks-pool0-27380386-vmss000001
✔ [POD_RUNNING] Found one pod running on node aks-pool0-27380386-vmss000001
✔ [LIST_PODS] Listed 1 pods on node aks-pool0-27380386-vmss000003
✔ [POD_RUNNING] Found one pod running on node aks-pool0-27380386-vmss000003
✔ [LIST_PODS] Listed 1 pods on node aks-pool0-27380386-vmss000002
✔ [POD_RUNNING] Found one pod running on node aks-pool0-27380386-vmss000002
✔ [LIST_PODS] Listed 1 pods on node aks-pool0-27380386-vmss000004
✔ [POD_RUNNING] Found one pod running on node aks-pool0-27380386-vmss000004
✔ [LIST_PODS] Listed 1 pods on node aks-pool1-27380386-vmss000000
✔ [POD_RUNNING] Found one pod running on node aks-pool1-27380386-vmss000000
✔ [LIST_PODS] Listed 1 pods on node aks-pool0-27380386-vmss000000
✔ [POD_RUNNING] Found one pod running on node aks-pool0-27380386-vmss000000
✔ [OSS(COMPONENT=MONITORING)]
✔ [OSS(component=monitoring)] Check for component monitoring passed
✔ [STORAGECLASS(NAME=STORAGE_CLASS_SINGLE_REPLICA)]
✔ [STORAGE_CLASS_EXISTS] Storage class azurefile-csi exists
✔ [CREATE_NAMESPACE] Created namespace prereqzb8mv
✔ [CREATE_STATEFULSET] Created statefulset storage-class-check-r9rzv
✔ [INGRESS]
✔ [INGRESS_FQDN_CHECK_TARGET_aks-pool0-27380386-vmss000000] Ingress check successful for url http://ci-asaks3955328.devtest-ascloudgen-ea.infra.uipath-dev.com:80
✔ [INGRESS_FQDN_CHECK_TARGET_aks-pool0-27380386-vmss000000] Ingress check successful for url http://ci-asaks3955328.devtest-ascloudgen-ea.infra.uipath-dev.com:443
✔ [INGRESS_FQDN_CHECK_TARGET_aks-pool0-27380386-vmss000001] Ingress check successful for url http://ci-asaks3955328.devtest-ascloudgen-ea.infra.uipath-dev.com:80
✔ [INGRESS_FQDN_CHECK_TARGET_aks-pool0-27380386-vmss000001] Ingress check successful for url http://ci-asaks3955328.devtest-ascloudgen-ea.infra.uipath-dev.com:443
✔ [INGRESS_FQDN_CHECK_TARGET_aks-pool0-27380386-vmss000002] Ingress check successful for url http://ci-asaks3955328.devtest-ascloudgen-ea.infra.uipath-dev.com:80
✔ [INGRESS_FQDN_CHECK_TARGET_aks-pool0-27380386-vmss000002] Ingress check successful for url http://ci-asaks3955328.devtest-ascloudgen-ea.infra.uipath-dev.com:443
✔ [INGRESS_FQDN_CHECK_TARGET_aks-pool0-27380386-vmss000003] Ingress check successful for url http://ci-asaks3955328.devtest-ascloudgen-ea.infra.uipath-dev.com:80
✔ [INGRESS_FQDN_CHECK_TARGET_aks-pool0-27380386-vmss000003] Ingress check successful for url http://ci-asaks3955328.devtest-ascloudgen-ea.infra.uipath-dev.com:443
✔ [INGRESS_FQDN_CHECK_TARGET_aks-pool0-27380386-vmss000004] Ingress check successful for url http://ci-asaks3955328.devtest-ascloudgen-ea.infra.uipath-dev.com:80
✔ [INGRESS_FQDN_CHECK_TARGET_aks-pool0-27380386-vmss000004] Ingress check successful for url http://ci-asaks3955328.devtest-ascloudgen-ea.infra.uipath-dev.com:443
✔ [CONNECTIVITY]
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-5dqxb on aks-pool0-27380386-vmss000000 can reach echo-a-5dqxb's IP 10.240.0.216 on aks-pool0-27380386-vmss000000
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-5dqxb on aks-pool0-27380386-vmss000000 can reach echo-a-9tl9f's IP 10.240.1.137 on aks-pool0-27380386-vmss000002
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-5dqxb on aks-pool0-27380386-vmss000000 can reach echo-a-g9vp7's IP 10.240.1.230 on aks-pool0-27380386-vmss000003
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-5dqxb on aks-pool0-27380386-vmss000000 can reach echo-a-hsr5v's IP 10.240.1.247 on aks-pool0-27380386-vmss000004
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-5dqxb on aks-pool0-27380386-vmss000000 can reach echo-a-wg6dl's IP 10.240.0.176 on aks-pool0-27380386-vmss000001
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-5dqxb on aks-pool0-27380386-vmss000000 can reach echo-a-zzbt8's IP 10.240.0.15 on aks-pool1-27380386-vmss000000
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-9tl9f on aks-pool0-27380386-vmss000002 can reach echo-a-5dqxb's IP 10.240.0.216 on aks-pool0-27380386-vmss000000
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-9tl9f on aks-pool0-27380386-vmss000002 can reach echo-a-9tl9f's IP 10.240.1.137 on aks-pool0-27380386-vmss000002
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-9tl9f on aks-pool0-27380386-vmss000002 can reach echo-a-g9vp7's IP 10.240.1.230 on aks-pool0-27380386-vmss000003
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-9tl9f on aks-pool0-27380386-vmss000002 can reach echo-a-hsr5v's IP 10.240.1.247 on aks-pool0-27380386-vmss000004
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-9tl9f on aks-pool0-27380386-vmss000002 can reach echo-a-wg6dl's IP 10.240.0.176 on aks-pool0-27380386-vmss000001
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-9tl9f on aks-pool0-27380386-vmss000002 can reach echo-a-zzbt8's IP 10.240.0.15 on aks-pool1-27380386-vmss000000
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-g9vp7 on aks-pool0-27380386-vmss000003 can reach echo-a-5dqxb's IP 10.240.0.216 on aks-pool0-27380386-vmss000000
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-g9vp7 on aks-pool0-27380386-vmss000003 can reach echo-a-9tl9f's IP 10.240.1.137 on aks-pool0-27380386-vmss000002
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-g9vp7 on aks-pool0-27380386-vmss000003 can reach echo-a-g9vp7's IP 10.240.1.230 on aks-pool0-27380386-vmss000003
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-g9vp7 on aks-pool0-27380386-vmss000003 can reach echo-a-hsr5v's IP 10.240.1.247 on aks-pool0-27380386-vmss000004
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-g9vp7 on aks-pool0-27380386-vmss000003 can reach echo-a-wg6dl's IP 10.240.0.176 on aks-pool0-27380386-vmss000001
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-g9vp7 on aks-pool0-27380386-vmss000003 can reach echo-a-zzbt8's IP 10.240.0.15 on aks-pool1-27380386-vmss000000
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-hsr5v on aks-pool0-27380386-vmss000004 can reach echo-a-5dqxb's IP 10.240.0.216 on aks-pool0-27380386-vmss000000
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-hsr5v on aks-pool0-27380386-vmss000004 can reach echo-a-9tl9f's IP 10.240.1.137 on aks-pool0-27380386-vmss000002
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-hsr5v on aks-pool0-27380386-vmss000004 can reach echo-a-g9vp7's IP 10.240.1.230 on aks-pool0-27380386-vmss000003
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-hsr5v on aks-pool0-27380386-vmss000004 can reach echo-a-hsr5v's IP 10.240.1.247 on aks-pool0-27380386-vmss000004
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-hsr5v on aks-pool0-27380386-vmss000004 can reach echo-a-wg6dl's IP 10.240.0.176 on aks-pool0-27380386-vmss000001
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-hsr5v on aks-pool0-27380386-vmss000004 can reach echo-a-zzbt8's IP 10.240.0.15 on aks-pool1-27380386-vmss000000
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-wg6dl on aks-pool0-27380386-vmss000001 can reach echo-a-5dqxb's IP 10.240.0.216 on aks-pool0-27380386-vmss000000
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-wg6dl on aks-pool0-27380386-vmss000001 can reach echo-a-9tl9f's IP 10.240.1.137 on aks-pool0-27380386-vmss000002
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-wg6dl on aks-pool0-27380386-vmss000001 can reach echo-a-g9vp7's IP 10.240.1.230 on aks-pool0-27380386-vmss000003
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-wg6dl on aks-pool0-27380386-vmss000001 can reach echo-a-hsr5v's IP 10.240.1.247 on aks-pool0-27380386-vmss000004
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-wg6dl on aks-pool0-27380386-vmss000001 can reach echo-a-wg6dl's IP 10.240.0.176 on aks-pool0-27380386-vmss000001
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-wg6dl on aks-pool0-27380386-vmss000001 can reach echo-a-zzbt8's IP 10.240.0.15 on aks-pool1-27380386-vmss000000
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-zzbt8 on aks-pool1-27380386-vmss000000 can reach echo-a-5dqxb's IP 10.240.0.216 on aks-pool0-27380386-vmss000000
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-zzbt8 on aks-pool1-27380386-vmss000000 can reach echo-a-9tl9f's IP 10.240.1.137 on aks-pool0-27380386-vmss000002
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-zzbt8 on aks-pool1-27380386-vmss000000 can reach echo-a-g9vp7's IP 10.240.1.230 on aks-pool0-27380386-vmss000003
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-zzbt8 on aks-pool1-27380386-vmss000000 can reach echo-a-hsr5v's IP 10.240.1.247 on aks-pool0-27380386-vmss000004
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-zzbt8 on aks-pool1-27380386-vmss000000 can reach echo-a-wg6dl's IP 10.240.0.176 on aks-pool0-27380386-vmss000001
✔ [OVERLAY_CONNECTIVITY_TEST] echo-a-zzbt8 on aks-pool1-27380386-vmss000000 can reach echo-a-zzbt8's IP 10.240.0.15 on aks-pool1-27380386-vmss000000
✔ [POD_TO_A] Scenario: http check between two random pods completed successfully
✔ [POD_TO_B_MULTI_NODE_CLUSTERIP] Scenario: http check between from pod to a multinode ClusterIP completed successfully
✔ [POD_TO_B_MULTI_NODE_HEADLESS] Scenario: http check between from pod to a multinode ClusterIP without a clusterIP set completed successfully
✔ [HOST_TO_B_MULTI_NODE_CLUSTERIP] Scenario: http check between from pod to a multinode ClusterIP using HostNetwork completed successfully
✔ [HOST_TO_B_MULTI_NODE_HEADLESS] Scenario: http check between from pod to a multinode ClusterIP without a clusterIP set using HostNetwork completed successfully
✔ [POD_TO_B_INTRA_NODE_CLUSTERIP] Scenario: http check between from two pods colocated on the same node via ClusterIP completed successfully
✔ [OSS(COMPONENT=CERT-MANAGER)]
✔ [OSS(component=cert-manager)] Check for component cert-manager passed
✔ [NODE(CPU >= 8, RAM >= 16GI)]
✔ [AT_LEAST_ONE_NODE] At least one node found
✔ [CPU_USAGE] Node aks-pool0-27380386-vmss000000 has 12.50% CPU usage
✔ [MEMORY_USAGE] Node aks-pool0-27380386-vmss000000 has 5.95% memory usage
✔ [POD_USAGE] Node aks-pool0-27380386-vmss000000 has 10.00% of pods in use. Number of pods: 10.00 max allowed: 100.00
✔ [CPU_CAPACITY(aks-pool0-27380386-vmss000000)] Node has enough CPU capacity. Has: 8, needs at least: 8
✔ [RAM_CAPACITY(aks-pool0-27380386-vmss000000)] Node has enough RAM capacity. Has: 32882800Ki, needs at least: 16Gi
✔ [CPU_USAGE] Node aks-pool0-27380386-vmss000001 has 12.50% CPU usage
✔ [MEMORY_USAGE] Node aks-pool0-27380386-vmss000001 has 6.04% memory usage
✔ [POD_USAGE] Node aks-pool0-27380386-vmss000001 has 23.00% of pods in use. Number of pods: 23.00 max allowed: 100.00
✔ [CPU_CAPACITY(aks-pool0-27380386-vmss000001)] Node has enough CPU capacity. Has: 8, needs at least: 8
✔ [RAM_CAPACITY(aks-pool0-27380386-vmss000001)] Node has enough RAM capacity. Has: 32882800Ki, needs at least: 16Gi
✔ [CPU_USAGE] Node aks-pool0-27380386-vmss000002 has 12.50% CPU usage
✔ [MEMORY_USAGE] Node aks-pool0-27380386-vmss000002 has 6.07% memory usage
✔ [POD_USAGE] Node aks-pool0-27380386-vmss000002 has 26.00% of pods in use. Number of pods: 26.00 max allowed: 100.00
✔ [CPU_CAPACITY(aks-pool0-27380386-vmss000002)] Node has enough CPU capacity. Has: 8, needs at least: 8
✔ [RAM_CAPACITY(aks-pool0-27380386-vmss000002)] Node has enough RAM capacity. Has: 32882800Ki, needs at least: 16Gi
✔ [CPU_USAGE] Node aks-pool0-27380386-vmss000003 has 12.50% CPU usage
✔ [MEMORY_USAGE] Node aks-pool0-27380386-vmss000003 has 6.41% memory usage
✔ [POD_USAGE] Node aks-pool0-27380386-vmss000003 has 23.00% of pods in use. Number of pods: 23.00 max allowed: 100.00
✔ [CPU_CAPACITY(aks-pool0-27380386-vmss000003)] Node has enough CPU capacity. Has: 8, needs at least: 8
✔ [RAM_CAPACITY(aks-pool0-27380386-vmss000003)] Node has enough RAM capacity. Has: 32882800Ki, needs at least: 16Gi
✔ [CPU_USAGE] Node aks-pool0-27380386-vmss000004 has 12.50% CPU usage
✔ [MEMORY_USAGE] Node aks-pool0-27380386-vmss000004 has 6.18% memory usage
✔ [POD_USAGE] Node aks-pool0-27380386-vmss000004 has 25.00% of pods in use. Number of pods: 25.00 max allowed: 100.00
✔ [CPU_CAPACITY(aks-pool0-27380386-vmss000004)] Node has enough CPU capacity. Has: 8, needs at least: 8
✔ [RAM_CAPACITY(aks-pool0-27380386-vmss000004)] Node has enough RAM capacity. Has: 32882796Ki, needs at least: 16Gi
✔ [CPU_USAGE] Node aks-pool1-27380386-vmss000000 has 12.50% CPU usage
✔ [MEMORY_USAGE] Node aks-pool1-27380386-vmss000000 has 6.01% memory usage
✔ [POD_USAGE] Node aks-pool1-27380386-vmss000000 has 11.00% of pods in use. Number of pods: 11.00 max allowed: 100.00
✔ [CPU_CAPACITY(aks-pool1-27380386-vmss000000)] Node has enough CPU capacity. Has: 8, needs at least: 8
✔ [RAM_CAPACITY(aks-pool1-27380386-vmss000000)] Node has enough RAM capacity. Has: 32882800Ki, needs at least: 16Gi
✔ [REGISTRY]
✔ [CONNECTIVITY] Successfully made Registry connection on Azure Container Registry | Microsoft Azure
✔ [OSS(COMPONENT=GATEKEEPER)]
✔ [OSS(component=gatekeeper)] Check for component gatekeeper passed
✔ [OSS(COMPONENT=LOGGING)]
✔ [OSS(component=logging)] Check for component logging passed
✔ [RESOURCE]
✔ [Capacity] Cluster has enough resources to run the given requirements
✔ [NETWORK-POLICIES]
✔ [CREATE_NAMESPACE] Namespace prereqmnfk5 created
✔ [CREATE_EGRESS_NETWORK_POLICY] Created the egress network policies allow-coredns-egress and block-external-traffic
✔ [CREATE_INGRESS_NETWORK_POLICY] Created the ingress network policy: block-echo-server-ingress
✔ [CREATE_SERVICE] Service echo-server-svc created
✔ [CREATE_ECHO_SERVER_POD] Echo server pod echo-server created
✔ [ECHO_SERVER_ACCESS] Echo server is expectedly not accessible from curl pod
✔ [DELETE_CURL_POD] Curl pod curl-pod deleted
✔ [UPDATE_NETWORK_POLICY] Network policy block-echo-server-ingress updated to allow traffic
✔ [UPDATE_NETWORK_POLICY] Network policy block-external-traffic updated to allow traffic
✔ [CURL_RESULT] Traffic to pod echo-server is allowed from pod curl-pod
✔ [INGRESS]
✔ [CONNECTIVITY]
✔ [REGISTRY]
✔ [RESOURCE]
