安装 Automation Suite
执行高级安装步骤,在 EKS/AKS 上部署 Automation Suite。
安装概述​
此页面将引导您完成 Automation Suite 的高级安装说明。
开始之前,请考虑以下事项:
  • 要部署和管理 Automation Suite,您必须了解 Kubernetes 和云资源管理方面的知识。 如果您在安装和配置 Automation Suite 时遇到问题,请联系 UiPath™ 专业服务。
  • Before choosing your deployment profile, refer to Deployment scenarios.
  • The installation process generates self-signed certificates on your behalf if you grant the installer admin privileges. You should replace them with certificates signed by a trusted Certificate Authority (CA) as soon as installation completes. For instructions, refer to Managing the certificates.
  • Automation Suite supports enabling Federal Information Processing Standard 140-2 (FIPS 140-2). For details, refer to Security and compliance.
运行安装程序​
To check which deployment scenarios are available for Automation Suite, refer to Deployment scenarios.
要安装 Automation Suite,请执行以下步骤:
  1. 成功验证先决条件后,您可以通过运行以下命令来安装 Automation Suite:
    uipathctl manifest apply input.json --versions versions.json
    For an output example, refer to Output example: Automation Suite installation.
    备注:
    如果在运行安装时遇到问题,请使用所有参数和标志重新运行安装命令。
    For details on the issues you might encounter, refer to Troubleshooting.
  2. 通过运行以下命令,验证安装是否成功以及服务是否运行正常:
    uipathctl health check --namespace <uipath> --versions versions.json
  • 安装概述​
  • 运行安装程序​
此页面有帮助吗?
连接
需要帮助? 支持
想要了解详细内容? UiPath Academy
有问题? UiPath 论坛
保持更新
