运行状况端点
EKS/AKS 上 Automation Suite 服务的运行状况检查端点。
要有效监控 Automation Suite 服务的运行状况,您可以使用本节中列出的运行状况端点。这些端点使您可以快速验证服务是否正常运行。
平台​
  • https://<automation-suite-fqdn>/pap_/health
  • https://<automation-suite-fqdn>/pdp_/health
  • https://<automation-suite-fqdn>/identity_/.well-known/openid-configuration
  • https://<automation-suite-fqdn>/identity_/web/
  • https://<automation-suite-fqdn>/lease_/health/
  • https://<automation-suite-fqdn>/license_/health
  • https://<automation-suite-fqdn>/organization_/health
  • https://<automation-suite-fqdn>/portal_/portal/shallow/healthStatus
  • https://<automation-suite-fqdn>/audit_/health
  • https://<automation-suite-fqdn>/resourcecatalog_/health
Action Center​
  • https://<automation-suite-fqdn>/actions_/
  • https://<automation-suite-fqdn>/bupproxyservice_/health/ready
  • https://<automation-suite-fqdn>/processes_/
Agents (智能体)​
  • https://<automation-suite-fqdn>/agents_/health
  • https://<automation-suite-fqdn>/agentsruntime_/health
AI Center​
  • https://<automation-suite-fqdn>/aifabric_/ai-app
  • https://<automation-suite-fqdn>/aifabric_/ai-deployer/actuator/health/ready
  • https://<automation-suite-fqdn>/aifabric_/ai-trainer/actuator/health/ready
  • https://<automation-suite-fqdn>/aifabric_/ai-pkgmanager/actuator/health/ready
  • https://<automation-suite-fqdn>/aifabric_/ai-helper/actuator/health/ready
  • https://<automation-suite-fqdn>/aistorage_/health
  • https://<automation-suite-fqdn>/<org-name>/apps_/default/api/v1/default/system-health
Autopilot for Everyone​
  • https://<automation-suite-fqdn>/autopilotforeveryone_/api/health
Autopilot for Developers​
  • https://<automation-suite-fqdn>/autopilotstudio_/alive
  • https://<automation-suite-fqdn>/autopilotstudio_/health
Automation Hub​
  • https://<automation-suite-fqdn>/automationhub_/fd-api/v1/ping
  • https://<automation-suite-fqdn>/automationstore_/fd-api/v1/ping
Solutions (解决方案)​
  • https://<automation-suite-fqdn>/automationsolutions_/health
Data Service​
  • https://<automation-suite-fqdn>/dataservice_/api/HealthCheck/health
  • https://<automation-suite-fqdn>/dataservice_/assets
Document Understanding​
  • https://<automation-suite-fqdn>/du_/api/documentmanager/health
  • https://<automation-suite-fqdn>/du_/api/storage/health
  • https://<automation-suite-fqdn>/du_/api/eventservice/health
  • https://<automation-suite-fqdn>/du_/metering/alive
  • https://<automation-suite-fqdn>/du_/ocr/info/ready
  • https://<automation-suite-fqdn>/du_/extended-ocr/ready
  • https://<automation-suite-fqdn>/du_/classify/MLclassification/info/ready
  • https://<automation-suite-fqdn>/du_/svc/formextractor/info
  • https://<automation-suite-fqdn>/du_/svc/intelligentkeywords/info
Enterprise Context Service (ECS)​
  • https://<automation-suite-fqdn>/ecs_/health
Healing Agent(语义代理)​
  • https://<automation-suite-fqdn>/semanticproxy_/health
Insights​
  • https://<automation-suite-fqdn>/insights_/health
Integration Service​
  • https://<automation-suite-fqdn>/connections_/schedulerstatus
  • https://<automation-suite-fqdn>/connections_/dispatcherstatus
  • https://<automation-suite-fqdn>/elements_/v1/elements/health
  • https://<automation-suite-fqdn>/elements_/elements/api-v2/tickle
LLM 网关​
  • https://<automation-suite-fqdn>/llmgateway_/health
LLM 可观察性​
  • https://<automation-suite-fqdn>/llmops_/health
  • https://<automation-suite-fqdn>/llmops_/tracesruntime/health
Maestro​
  • https://<automation-suite-fqdn>/pims_/api/health
通知服务​
  • https://<automation-suite-fqdn>/notificationservice_/notificationserviceapi/health/readiness
  • https://<automation-suite-fqdn>/notificationservice_/usersubscriptionservice/health/readiness
  • https://<automation-suite-fqdn>/notificationservice_/publishermetaservice/health/readiness
Orchestrator​
  • https://<automation-suite-fqdn>/orchestrator_/api/health
机器人管​
  • https://<automation-suite-fqdn>/robotube_/healthz
ScreenPlay(语义代理)​
Studio 监管​
  • https://<automation-suite-fqdn>/roboticsops_/api/health
Studio Web​
  • https://<automation-suite-fqdn>/studio_/backend/healthz
  • https://<automation-suite-fqdn>/studio_/typecache/healthz/readiness
Test Manager​
  • https://<automation-suite-fqdn>/testmanager_/api/health/live
检查服务运行状况​
要检查特定服务的运行状况,请将请求发送到其相应的端点,如以下示例所示。
curl -kiso /dev/null -w "%{http_code}" https://<automation-suite-fqdn>/orchestrator_/api/health
HTTP 状态代码 200 的成功响应表示服务运行良好。
此页面有帮助吗?
连接
需要帮助? 支持
想要了解详细内容? UiPath Academy
有问题? UiPath 论坛
保持更新
