# API References
> The [Automation Hub API Swagger](https://automation-hub.uipath.com/api/v1/api-doc/) definition can be accessed directly by adding the Authentication details in the Authorization key in the request call named **Header**.
`https://cloud.uipath.com/{orgName}/{tenantName}/automationhub_/api/v1/api-doc/`
The guide herein is built to support the **Swagger** documentation, by providing relevant and easy to follow examples.
To use Swagger documentation in Delayed Release Organizations, use the following link:
If you prefer to work with **Postman**, [create a Postman environment](https://learning.postman.com/docs/postman/variables-and-environments/managing-environments/). Afterwards, check out our API collection made available in [Postman](https://automation-hub-postman.uipath.rocks/?version=latest). The collection can be imported by clicking the **Run in Postman** button.
