Test Suite
2020.10
  • Studio installation
    • Installing Studio
  • Robot installation
  • Orchestrator installation
  • Test Manager installation
Banner background image
OUT OF SUPPORT
Test Suite Installation Guide
Last updated Feb 28, 2024
Installation
Prerequisites
  • Check and before installation.
  • Install Test Automation feature in Orchestrator. You can enable this feature by modifying an existing Orchestrator Single Node Installation and choosing Test Automation during setup.
    Note: When you enable the Test Automation feature in the Orchestrator, it creates a dedicated database with the default name UiPathTestAutomation. This database differs from the one created during the Test Manager installation.
  • Download the UiPath Test Manager installation kit.
  • Configure the SQL Server instance that you want to use to install Test Manager, using the following requirements:
    • the name of the SQL Server machine;
    • the name of the instance, if it’s not the default instance;
    • the value of the TCP port, if it’s not the default port - 1433;
    • the SQL Server port is open in the firewall of the SQL Server machine;
    • the TCP Protocol in SQL Server Configuration Manager has to be enabled;
    • the SQL Server service needs to listen on a fixed port, not on a dynamically allocated one.
  • Prerequisites
