test-manager
  • Getting started
    • Getting started
      • Integrating with Studio
      • Creating a project
  • Project management
  • Project operations and utilities
  • Test Manager settings
  • ALM tool integration
  • API integration
Test Manager user guide
Last updated Oct 21, 2025
Getting started
Assign an Orchestrator instance to Test Manager
To start using your Test Manager, you need to install and enable the Test Automation module, as part of the Orchestrator installation process.
As part of the Test Manager installation process, you must provide an Orchestrator instance, through the Orchestrator URL that you want to connect Test Manager to. Visit Installation for more information about installing Test Manager.
Prerequisites
Log into your UiPath standalone product installations organization as an administrator.
Allocate user licenses
To access Test Manager, you need to ensure that after installing Test Manager you allocate at least one Testing Runtime license at the tenant level. Visit the Post-installation steps for Test Manager to learn more information.
Document test cases with Task Capture
UiPath® Task Capture is a process discovery tool that helps you document your test cases to avoid manually downloading the images and typing titles for each of the included actions.
Working in the background, the tool captures the performed steps, takes screenshots with every mouse click, and collects smart data about the process statistics (execution time, number of steps, text entries, etc.). You can edit and annotate each screenshot and add information for each step.
Based on the captured data, UiPath® Task Capture builds a comprehensive Process Definition Document (PDD) in a .ssp, .docx and .jpg (diagram image) format that can be easily uploaded to Test Manager.
For more information, see Task Capture Introduction.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
