- Getting started
- Project management
- Project operations and utilities
- Test Manager settings
- ALM tool integration
- API integration
In this section, you can build your testing portfolio and learn how to manage test cases and test sets in Test Manager, and document test cases through Task Capture:
To start using your Test Manager, you need to install and enable the Test Automation module, as part of the Orchestrator installation process.
As part of the Test Manager installation process, you must provide an Orchestrator instance, through the Orchestrator URL that you want to connect Test Manager to. Visit Installation for more information about installing Test Manager.
Log into your UiPath standalone product installations organization as an administrator.
To access Test Manager, you need to ensure that after installing Test Manager you allocate at least one Testing Runtime license at the tenant level. Visit the Post-installation steps for Test Manager to learn more information.
- Administrative Test Manager functions such as, creating projects, Integrating Application Lifecycle Management tools, or defining custom fields can only be done by Test Manager Administrators.
- A user that is an organization administrator is also a Test Manager Administrator.
- An Test Manager Administrator also requires a Tester - Named User license for using Test Manager.
- To correctly sync results between Orchestrator and Test Manager, make sure the folder from which you are executing tests is available for the admin user. For more information, see Roles.
