# Project management
> For each of your projects, you have the option to view and edit its **Name** and **Description** by selecting the **Edit** option in the project menu or review the project progress through its specific Dashboard page by accessing the **Go to Project page**.
![Go to Project page option](https://dev-assets.cms.uipath.com/assets/images/task-mining/task-mining-go-to-project-page-option-131393-63afd028-4fc104fa.webp)
* **Open a linked AiCenter project** lets you open the respective project in AiCenter.
* **Delete** option provides the ability to delete a project. Once a project is deleted, it cannot be recovered.
  ![Only archived projects can be deleted](https://dev-assets.cms.uipath.com/assets/images/task-mining/task-mining-only-archived-projects-can-be-deleted-132191-9ae1a01b-c588530c.webp)
* **Archive** option lets users archive the project and any other information added or captured will not be integrated in the respective project.
  ![Archive option](https://dev-assets.cms.uipath.com/assets/images/task-mining/task-mining-archive-option-132934-1bc5fff1-3e4ea8e5.webp)
* **Restore** is available only on **Archived** projects and lets users enable the project and continue to add information.
  ![Only archived projects can be restored](https://dev-assets.cms.uipath.com/assets/images/task-mining/task-mining-only-archived-projects-can-be-restored-130959-9cd82620-e5bf1af1.webp)
## Renaming a project
To rename an existing project follow the steps below:
1. In the Web Discovery Portal select the project you wish to rename.
2. Select **Edit**.
   ![Edit project option](https://dev-assets.cms.uipath.com/assets/images/task-mining/task-mining-edit-project-option-291036-86ffcded-e490778b.webp)
3. Rename your project in the **Project Name** box and select **Save**. If needed, you can also add some details about the project in the **Description** box.
   ![Project details](https://dev-assets.cms.uipath.com/assets/images/task-mining/task-mining-project-details-132427-dbbb861a-c221c670.webp)
