# Using imported library projects in coded automations
> Use Object Repository elements and workflows from imported library projects within coded automations in Studio.
This tutorial shows you how to use objects from imported library projects within coded automations. The example demonstrates how to use Object Repository elements and workflows from an imported library project. The given scenario involves automating the Acme website, to fill in a student score card and add it to the database.
## Prerequisites
* Install UIAutomation Activities version 23.10.13 or higher.
  :::note
  We recommend you to use the latest minor version corresponding to the major version that you are working with. For example, if you are using the 23.10 major version of activity packages, we recommend you to upgrade them to the latest minor version available (`23.10.x`).
* Publish the Acme library sample and install it in the project where you are working.
## 1. Create the library project
Create a library project to store the essential UI elements for automating the Acme App, specifically for filling a student score card. Additionally, create a low-code (`.xaml`) or coded workflow (`.cs`) within the library project, that you will later use within another coded automation.
1. Create a library project named `AcmeLibrary`.
2. Capture all the UI elements that you want to use inside the **Object Repository**, and **Descriptors** section.
3. Create a new **Coded Workflow**, from the **File** group. This step is crucial to enable access to the Object Repository within a coded automation when importing the library in another project.
4. Rename the **Main** low-code workflow to `Send message box`, and add a **Message box** activity, with the following text: *"You've added a new score card for a student in Acme."*
   :::note
   You can recreate the **Message Box** activity as a coded workflow, as well, by following the steps outlined in the tutorial.
5. Save and publish the library project to a feed. You will install and use this published library in another project within a coded automation.
### Result
The library project is published to the feed and available to install in other projects.
## 2. Create the coded automation
After you create the library project, install it into another project to leverage its reusable assets, including Object Repository elements and workflows, whether they are low-code (`.xaml`) or coded (`.cs`).
:::tip
When using UI Automation coded automation APIs, remember that the overloads with `IScreenDescriptor` or `IElementDescriptor` are intended to work with Object Repository elements, while the overloads with `TargetAnchorableModel` are meant for use with native selectors obtained through the **UI Explorer**. Visit [UI Automation coded automation APIs](https://docs.uipath.com/activities/other/latest/ui-automation/ui-automation-apis) to learn how to leverage selectors with UI Automation coded automation APIs.
1. From the **File** group, create a new **Coded Workflow**.
2. Go to **Manage Packages** and install the library project you previously created.
3. From the **File** group, create a new **Workflow**.
   1. Name the workflow `notifyStudentScoreCardAdded`.
   2. Navigate to the **Activities** panel, to the **Installed** section.
   3. Search for the name of the library project you imported (for this example, `AcmeLibrary`).
   4. Drag and drop the `Send message box` activity inside `notifyStudentScoreCardAdded`. Now the `notifyStudentScoreCardAdded` has the same behavior as the `Send message box` workflow from the imported library project.
4. To enhance readability, you can define your imported Object Repository application as a variable applying a `using` statement at the beginning of your workflow. Here is an example: `using app = <ProjectName>.ObjectRepository.Descriptors`.
With this approach, you can easily call descriptors in the following format: `app.<AppName>.<ScreenName>.<UiElementName>`
For this example, we define the Acme Object Repository like the following:
   namespace UsingImportedLibraryProjects
       using AcmeApp = AcmeLibrary.ObjectRepository.Descriptors;
5. Now you can automate the given scenario within Acme. Start by opening the Acme login screen using the **Open** coded automation API.
    [Workflow]
           public void Execute()
             // 1.Open the Acme app on the Login screen
             var AcmeLoginScreen = uiAutomation.Open(AcmeApp.Acme.LoginScreen);
6. Type in the necessary credentials for logging into Acme, using the **TypeInto** coded automation API.
     // 2.Type in the necessary credentials
            AcmeLoginScreen.TypeInto(AcmeApp.Acme.LoginScreen.Email, "john.doe2023@uipath.com");
            AcmeLoginScreen.TypeInto(AcmeApp.Acme.LoginScreen.Password, "12345678");
7. Use the **Select** coded automation API, along with a native selector, to select the **Login** button.
   // 3.Use a native selector to click the Login button
   AcmeLoginScreen.Click(Target.FromSelector("<webctrl tag='BUTTON' type='submit'/>"));
8. The login process takes you to the **Dashboard** screen in the Acme web application. Therefore, use the **Attach** coded automation API to focus on the new screen.
   // 4. Focus on the Dashboard screen
   var DashboardScreen = uiAutomation.Attach(AcmeApp.Acme.Dashboard);
9. Select the **Students** entry on the website, using the **Select** coded automation API.
   // 5. Click the Students entry
   DashboardScreen.Click(AcmeApp.Acme.Dashboard.Students);
10. Select **Score card** to open the **Students - Score Card** form, using the **Select** coded automation API.
    // 6. Click Score card, to start filling in a student score card
    DashboardScreen.Click(AcmeApp.Acme.Dashboard.Students.ScoreCard);
11. Focus on the **Students - Score Card** screen, using the **Attach** coded automation API.
    // 7. Focus on the Score Card screen where you fill in the necessary information
    var ScoreCardScreen = uiAutomation.Attach(AcmeApp.Acme.StudentsScoreCard);
12. Fill in half of the fields in the Students - Score Card form using the **TypeInto** coded automation API, and elements from the Object Repository.
    ScoreCardScreen.TypeInto(AcmeApp.StudentsScoreCard.StudentEmail, "john.doe@uipath.com");
    ScoreCardScreen.TypeInto(AcmeApp.Acme.StudentsScoreCard.FirstName, "John");
    ScoreCardScreen.TypeInto(AcmeApp.Acme.StudentsScoreCard.LastName, "Doe");
    ScoreCardScreen.TypeInto(AcmeApp.Acme.StudentsScoreCard.ParentEmail, "johnny.doe@uipath.com");
    ScoreCardScreen.TypeInto(AcmeApp.Acme.StudentsScoreCard.Tuition, "Private");
13. Fill in the rest of the fields in the form using the **TypeInto** coded automation API in combination with native selectors that you discover through the UI Explorer.
    ScoreCardScreen.TypeInto(Target.FromSelector("<webctrl id='mathematics' tag='INPUT' />"), "A");
    ScoreCardScreen.TypeInto(Target.FromSelector("<webctrl id='physics' tag='INPUT' />"), "B");
    ScoreCardScreen.TypeInto(Target.FromSelector("<webctrl id='biology' tag='INPUT' />"), "C");
    ScoreCardScreen.TypeInto(Target.FromSelector("<webctrl id='chemistry' tag='INPUT' />"), "A");
    ScoreCardScreen.TypeInto(Target.FromSelector("<webctrl id='geography' tag='INPUT' />"), "C");
    ScoreCardScreen.TypeInto(Target.FromSelector("<webctrl id='history' tag='INPUT' />"), "A");
    ScoreCardScreen.TypeInto(Target.FromSelector("<webctrl id='english' tag='INPUT' />"), "A");
    ScoreCardScreen.TypeInto(Target.FromSelector("<webctrl id='computer Science' tag='INPUT' />"), "C");
    ScoreCardScreen.TypeInto(Target.FromSelector("<webctrl id='professorComments' tag='INPUT' />"), "The student is doing okay, very hardworking and does its best");
14. Select **Add score card details** using the **Select** coded automation API.
    // 10. Click the "Add score card details" button using an Object Repository descriptor
    ScoreCardScreen.Click(AcmeApp.Acme.StudentsScoreCard.AddScoreCardDetailsButton);
15. Invoke the workflow you imported from the library project using the `RunWorkflow()` method. Provide the method with the path of the workflow inside the project.
    // 11. Invoke imported workflow from library
    RunWorkflow("notifyStudentScoreCardAdded.xaml");
16. Close the browser tabs you opened to automate the scenario, using the `Dispose()` coded automation API.
    // 12. Close the applications/browsers you opened, to finish he automation
    ScoreCardScreen.Dispose();
### Result
The coded automation runs successfully. The student score card is filled in the Acme application, and a message notification is displayed. The browser tabs are closed when the automation completes.
## Sample project
To follow the steps and try out the tutorial yourself, see the following sample project: [Using imported library projects in coded automations](https://dev-assets.cms.uipath.com/assets/examples/CodedAutomations/UsingImportedLibraryObjectInsideCodedAutomations.zip). The file contains the library project, as well.
