# About Control Flow
> An important aspect of successfully working with Studio is understanding and knowing how to control your project. **Control Flow** is a concept borrowed from computer science that refers to the order in which actions are performed in an automation.
A proper **Control Flow** can be achieved through the intelligent use of variables and activities.
All of these activities can be found in the **Activities** panel, under **Workflow &gt; Control**.
![docs image](https://dev-assets.cms.uipath.com/assets/images/studio/studio-docs-image-169933-7fe9e2b9.webp)
These activities enable you to define rules and automate conditional statements within the project, through **if/else** and **for each** statements or **loops**.**Delay** can also be added between actions, in order to perfectly time activities.
**Loops** represent an important part of automations as they enable you to easily check dependencies between variables, activities and conditions. Once created, they enable the user to run a segment of the automation for a specific number of times, until a condition is met, or indefinitely.
