# Configure a multi-hop connection
> To reach a destination remote computer via multiple connections, you must install Remote Runtime on each intermediary remote computer, not only on the final target computer.
## Scenario: RDP connections
Consider the following scenario:
* Machine A (with Studio and/or Robot) connects via RDP (Microsoft Remote Desktop Protocol) to Machine B, and
* Machine B connects via RDP to Machine C, where the target application is running, and the automation must be performed.
In this example, the following configuration is required:
1. Machine A – install Studio/Robot and the **Extension for Microsoft Remote Desktop and Apps** (UiPath RDP extension).
2. Machine B – install the **Extension for Microsoft Remote Desktop and Apps** and `UiPathRemoteRuntime.msi`.
3. Machine C – install `UiPathRemoteRuntime.msi`.
   ![docs image](https://dev-assets.cms.uipath.com/assets/images/studio/standalone-docs-image-373848-1ddae002.webp)
If other types of connections are used between two machines, you must configure a connection at each hop, with the appropriate extension:
* **Extension for Citrix** for the case of Citrix connection
* **Extension for Microsoft Remote Desktop and Apps** (UiPath RDP extension) for the case of RDP connection
* **Extension for VMWare Horizon** for the case of VMWare connection
## Scenario: RDP connection and Citrix connection
Let's consider another scenario in which:
* Machine A (with Studio and/or Robot) connects via RDP to Machine B, and
* Machine B connects via Citrix to Machine C, where the target application is running, and the automation must be performed.
  ![docs image](https://dev-assets.cms.uipath.com/assets/images/studio/standalone-docs-image-373852-e7fc023f.webp)
On Machine B (or other intermediary machines), you can install the extension with one of these methods:
* Run the `UiPathRemoteRuntime.msi` installer and select from the **Product Features** list the required extension. Refer to [Installing the UiPath Remote Runtime - From the Installer](https://docs.uipath.com/studio/standalone/2024.4/user-guide/about-uipath-remote-runtime#from-the-installer).
* From Command Prompt run `SetupExtensions.exe` (located in the folder `C:\Program Files (x86)\UiPath\RemoteRuntime`) with the parameter corresponding to the required extension:
  + [Commands for the UiPath Extension for Citrix](https://docs.uipath.com/studio/standalone/2024.4/user-guide/about-the-setupextensions-tool#commands-for-the-uipath-extension-for-citrix)
  + [Commands for the UiPath Extension for Windows Remote Desktop](https://docs.uipath.com/studio/standalone/2024.4/user-guide/about-the-setupextensions-tool#commands-for-the-uipath-extension-for-windows-remote-desktop)
  + [Commands for the UiPath Extension for VMware Horizon](https://docs.uipath.com/studio/standalone/2024.4/user-guide/about-the-setupextensions-tool#commands-for-the-uipath-extension-for-vmware-horizon)
## Automating Java or web applications
Regardless of your multi-hop connection scenario, if you are automating a Java application or a web application, you must also install the corresponding extension (the extension for Java, Chrome, Microsoft Edge, Firefox) on the remote machine. This can be done by running:
* the `UiPathRemoteRuntime.msi` installer, as described in [Installing the UiPath Remote Runtime](https://docs.uipath.com/studio/standalone/2024.4/user-guide/about-uipath-remote-runtime#installing-the-uipath-remote-runtime), or
* the `SetupExtensions.exe` tool located in the installation folder of **UiPath Remote Runtime** (default `%ProgramFiles(x86)\UiPath\RemoteRuntime`), as described in [About the SetupExtensions tool](https://docs.uipath.com/studio/standalone/2023.10/user-guide/about-the-setupextensions-tool).
