# Known issues specific to MV3 extensions
> The Click activity with the `Simulate` input method no longer works on HTML elements that have a click handler with `javascript:` URI.
## Click activity with Simulate fails on specific web page elements
![docs image](https://dev-assets.cms.uipath.com/assets/images/studio/standalone-docs-image-168089-fe7781dd.webp)
In this case, the simulated click will not take effect and no errors will be reported.
This was reported as a [Chromium bug](https://bugs.chromium.org/p/chromium/issues/detail?id=1299742). This issue is quite rare as very few HTML elements have click handlers in this form.
### **Workarounds**
Two workarounds are available for this issue:
1. Identify the failing **Click** activity in your workflow and change the input method from **Simulate** to any other input method (Chromium API, Hardware Events, Window Messages).
2. Upgrade to **UiPath.UIAutomation.Activities** package **v22.12** or newer and use the **Enable workaround for simulate click with MV3 extension** option in [Project Settings](https://docs.uipath.com/activities/other/latest/user-guide/project-settings-ui-automation#browser).
## The DeveloperToolsAvailability Group Policy value must be set to 1
The [DeveloperToolsAvailability](https://docs.microsoft.com/en-us/deployedge/microsoft-edge-policies#developertoolsavailability) has the following possible values:
* 0 = Disallow usage of the Developer Tools on extensions installed by enterprise policy, allow usage of the Developer Tools in other contexts
* 1 = Allow usage of the Developer Tools
* 2 = Disallow usage of the Developer Tools
If the UiPath Extension for Edge is installed using [Group Policy](https://docs.uipath.com/studio/standalone/2023.10/user-guide/extension-for-edge-chromium#install-from-group-policy), then the [DeveloperToolsAvailability](https://docs.microsoft.com/en-us/deployedge/microsoft-edge-policies#developertoolsavailability) must be set to `1` to enable the full functionality of the extension.
This value is automatically set correctly when the extension is installed but it will be overwritten if your system administrator has set another value for this policy.
The other values for [DeveloperToolsAvailability](https://docs.microsoft.com/en-us/deployedge/microsoft-edge-policies#developertoolsavailability) cause the problems listed below.
If [DeveloperToolsAvailability](https://docs.microsoft.com/en-us/deployedge/microsoft-edge-policies#developertoolsavailability) is set to `0` then:
* The UiPath Extension for Edge will be restricting to working with LTS versions of UiAutomation (19.10.x, 20.10.x, 21.10.x, 22.4.x)
* The `InjectJS` Activity will not work.
If [DeveloperToolsAvailability](https://docs.microsoft.com/en-us/deployedge/microsoft-edge-policies#developertoolsavailability) is set to `2` then:
* All the limitations from `DeveloperToolsAvailability=0` apply
* The `ChromiumAPI` input method will not work.
## The UiPath Web Automation browser window shows a warning
The UiPath Web Automation browser window shows the following warning if `ChromeNativeMessaging.exe` could not be started:
`Cannot communicate with UiPath Platform The native part of the extension is not configured correctly.`
Re-install the extension from UiPath Studio.
  !['Cannot communicate with UiPath Platform' image](https://dev-assets.cms.uipath.com/assets/images/studio/standalone-cannot-communicate-with-uipath-platform-image-592725-d63b7c34.webp)
See [Check if ChromeNativeMessaging.exe is running](https://docs.uipath.com/studio/standalone/2023.10/user-guide/check-if-chromenativemessagingexe-is-running-edge#check-if-chromenativemessagingexe-is-running).
## The Inject Js Script activity can no longer be used to access page variables and code
By default, the **Inject Js Script** activity can no longer be used to access page variables, such as `jQuery $` , or to interact with page code (e.g., `window.alert`). The **Inject Js Script** activity won't report an error, but the script will fail to execute and the following error will be reported in the browser DevTools (F12): "Refused to execute inline script because it violates the following Content Security Policy directive."
  !['Console tab' image](https://dev-assets.cms.uipath.com/assets/images/studio/standalone-console-tab-image-592735-c3f61e55.webp)
This is a limitation introduced by the MV3 platform.
To fix this issue, select the **Execution world - Page** option from the **[Inject Js Script](https://docs.uipath.com/activities/docs/n-inject-js-script)** activity.
Your existing JavaScript code doesn't require any changes, and by using the **Execution world - Page** option it will work for both MV2 and MV3 extensions.
## Open Browser activity has an insufficient timeout
For MV3 extensions, the browser loads the extension later, after the web pages have loaded. This means that on slower machines, the **Open Browser** activity from **UiPath.UiAutomation.Activities** version 22.10 or older can reach the internal timeout of 20 seconds before the extension has started.
Starting with v22.12.0-preview, the internal timeout for the **Open Browser** activity has been increased from 20 seconds to 60 seconds.
Since you may need to set a longer timeout for the browser startup, it is now configurable from the **Use Application/Browser** and **Open Browser** activities. The following project settings have been added:
* **UI Automation Classic** → **Browser** → [Open browser timeout (seconds)](https://docs.uipath.com/activities/other/latest/user-guide/project-settings-ui-automation)
* **UI Automation Modern** → **Application/Browser** → [Open browser timeout (seconds)](https://docs.uipath.com/activities/other/latest/user-guide/project-settings-ui-automation-next)
Additionally, you can configure the timeout through the `UIPATH_OPEN_BROWSER_TIMEOUT_SECONDS` environment variable. For example, set `UIPATH_OPEN_BROWSER_TIMEOUT_SECONDS=120` to use 120 seconds for the activity's timeout.
