# Robot terminology
> Definitions of the terms used across the UiPath Robot 2026.10 admin guide, each paired with the term it is most often confused with.
Each term has one meaning in this guide. Where two terms are often mixed up, the last column names the one it is not.
| Term | Definition | Not to be confused with |
| Agent slot | Capacity on a machine template for one concurrent agent job on each connected machine. | Runtime |
| Attended automation | Automation a person starts and supervises on their own machine, using their own credentials. | Unattended automation |
| Executor | The part of Unified Runtime that runs one kind of workload: the .NET executor for RPA processes and test cases, executor packages for agents, functions, and API workflows. | Unified Runtime |
| Function slot | Capacity on a machine template for one concurrent function or API workflow job on each connected machine. Doesn't apply when **Use Production (Unattended)** is selected on the machine template. | Runtime |
| Install mode | How the Robot is installed on a machine: service mode or user mode. | Attended automation |
| Machine object | Orchestrator's record of one or more machines: a machine template or a standard machine, with its runtimes and slots. | Robot host |
| Robot account | The Orchestrator identity a robot runs and connects as. | UiPath Robot |
| Robot host | The machine the Robot runs on. | Machine object |
| Runtime | A license that lets one unattended RPA or test job run at a time on a machine. | Unified Runtime, runtime type |
| Runtime type | The choice Orchestrator makes for a job: which license or capacity it runs on, such as **Production (Unattended)**, **Testing**, or **Local**. | Runtime |
| Service mode | A per-machine installation with the **Unattended** robot type, in which the Robot runs as a Windows service. Used for unattended automation, and for attended automation on the same machine. | User mode |
| UiPath Platform Installer | The installer that installs and updates Studio, Robot, Assistant, and browser extensions, and keeps them on an update channel. | Update channel |
| UiPath Robot | The execution layer of the UiPath Platform. It runs the jobs Orchestrator dispatches. | Robot host, robot account |
| Unattended automation | Automation that runs without a person present, started by Orchestrator, a trigger, or another automation. | Attended automation |
| Unified Runtime | The Robot's single runtime. It runs every workload, handing each job to the executor that workload needs. | Runtime |
| Units | Consumption currency: Platform Units in Unified Pricing, Agent Units in Flex. | Runtime |
| Update channel | The release line a machine follows: Community, Enterprise STS, or an Enterprise LTS line such as 26.10. | Install mode |
| User mode | An installation without the Robot Windows service, in which the Robot runs in the signed-in user's session, for attended automation. A per-user installation, or a per-machine installation with the **Attended** robot type. | Service mode |
| Workload | The kind of job the Robot runs: an RPA process, a test case, an agent, a function, or an API workflow. | Robot host |
For the platform-wide glossary, refer to the [UiPath glossary](https://docs.uipath.com/overview/other/latest/overview/uipath-glossary).
