# SDK Specifications
> You can include the following methods and properties in your custom application or web page.
## Methods and properties
### Init
The `init` method is optional. It returns the **IRobotSDK** instance, which enables you to store it as a variable for later use.
const robot = UiPathRobot.init();
### Settings
The `settings` property of type Settings allows you to change the default port number, the poll interval time in milliseconds, or to disable sending telemetry data.
robot.settings.portNumber = 1234;
robot.settings.pollTimeInterval = 1000;
robot.settings.disableTelemetry = true;
### On
The `on` method is used to attach event handlers to the SDK.
The available SDK events are `consent-prompt`, `missing-components` and `open-uipath-protocol`.
### consent-prompt
The UiPath JavaScript SDK comes with a built-in consent overlay displayed every time your custom application or web page needs to connect to the Robot.
This consent overlay can be overridden with a custom handler.
robot.on('consent-prompt', consentCode => console.log(consentCode));
### missing-components
The `missing-components` event is raised when the Robot JS Service is not running. In this case, the SDK displays an error, which can be overridden with a custom handler.
robot.on('missing-components', () => console.log('Missing Components'));
### open-uipath-protocol
Before being shown the consent prompt you might be asked to allow the browser to open a uipath-web URL in the associated application.
By default, RobotJS will automatically try to open this URL, but users can override this behavior by providing a custom event handler.
robot.on('open-uipath-protocol', (protocolUrl) => console.log('RobotJS protocol URL: ' + protocolUrl));
### Get Processes
The `getProcesses` method retrieves the list of available processes. Returns a Promise to an array of [RobotProcess](https://docs.uipath.com/robot/standalone/2025.10/developer-guide/sdk-specifications#sdk-specifications) objects. If the Robot is connected to Orchestrator, it retrieves the processes from the environment and folder the Robot is a part of. Otherwise, local processes are retrieved.
const processes = await robot.getProcesses();
for(let i=0; i<processes.length; i++){
    console.log(processes[i].name + " (" + processes[i].description + ") - Id=" + processes[i].id);
### Get Input Arguments Schema
Using the `inputArgumentsSchema` property of an installed process, you can retrieve the input arguments of a process. Before using the `inputArgumentsSchema` property, you need to first install the process.
The `installProcess` method installs a process and returns a Promise to an object of type [InstallProcessResult](https://docs.uipath.com/robot/standalone/2025.10/developer-guide/sdk-specifications#sdk-specifications), which contains an array of [InputArgumentSchema](https://docs.uipath.com/robot/standalone/2025.10/developer-guide/sdk-specifications#sdk-specifications) objects.
const installedProcess = await robot.installProcess(processes[0].id);
for(let i=0; i<installedProcess.inputArgumentsSchema.length; i++){
    console.log("Argument " + i + ":");
    console.log("  name: " + installedProcess.inputArgumentsSchema[i].name)
    console.log("  type: " + installedProcess.inputArgumentsSchema[i].type)
    console.log("  isRequired: " + installedProcess.inputArgumentsSchema[i].isRequired)
    console.log("  hasDefault: " + installedProcess.inputArgumentsSchema[i].hasDefault)
:::note
In TypeScript, the method `install` of a [RobotProcess](https://docs.uipath.com/robot/standalone/2025.10/developer-guide/sdk-specifications#sdk-specifications) object can be used to install a process.
const myProcess = processes.find(p => p.name === "MyProcess");
const installedProcess = await myProcess.install();
### Start Job
The `startJob` method receives an already created `Job` and starts it. It returns a Promise to an object of type [JobResult](https://docs.uipath.com/robot/standalone/2025.10/developer-guide/sdk-specifications#sdk-specifications), which contains the output arguments.
The `createJob` method creates a robot Job using the Process Id. It can optionally receive the job input arguments. It returns a [Job](https://docs.uipath.com/robot/standalone/2025.10/developer-guide/sdk-specifications#sdk-specifications) object.
:::note
Starting with v2022.10, the process list is refreshed in parallel with the process execution, prior to this, the process list was refreshed before the process started. This means that when running a process for which an update is available, the job might run with the older version of the process.
const calculatorProcess = processes.find(p => p.name.includes('Calculator'));
const arguments = {
    "input1" : 23,
    "input2" : 42,
    "operation" : "add"
const job = robot.createJob(calculatorProcess.id, arguments);
const result = await robot.startJob(job);
console.log(result.Sum);
:::note
In TypeScript, a Job can be created by using the [Job](https://docs.uipath.com/robot/standalone/2025.10/developer-guide/sdk-specifications#sdk-specifications) class constructor.
const arguments = {
    "input1" : 23,
    "input2" : 42,
    "operation" : "add"
const job = new Job(calculatorProcess.id, arguments);
### Job On
The `on` method of the `Job` object is used to attach event handlers to the job . The events available are `status` and `workflow-event`.
### status
The `status` event is raised during the job execution each time the status of the job has changed.
This event is also raised each time the [ReportStatus](https://docs.uipath.com/activities/docs/report-status) activity is executed.
const job = robot.createJob('processId');
job.on('status', robotStatus => console.log(robotStatus));
### workflow-event
The `workflow-event` event is raised during the job execution each time an activity that sends a workflow event is executed. It is the support for implementing partial results with the help of [send interim results](https://docs.uipath.com/activities/docs/send-interim-result) activity. The event handler has an argument of type [WorkflowEventData](https://docs.uipath.com/robot/standalone/2025.10/developer-guide/sdk-specifications#sdk-specifications).
job.on('workflow-event', e => console.log(e.name));
### Start Process
The method `start` of the object [RobotProcess](https://docs.uipath.com/robot/standalone/2025.10/developer-guide/sdk-specifications#sdk-specifications) is used to start a process by passing it input arguments, if available.
It returns an object of type [JobPromise](https://docs.uipath.com/robot/standalone/2025.10/developer-guide/sdk-specifications#sdk-specifications).
const arguments = {
    "a" : 41,
    "b" " 27
const result = await myProcess.start(arguments);
### Process On Status
The `onStatus` method is used to attach an event handler to the 'status' event of the Job.
const result = await myProcess.start().onStatus(status => console.log(status));
### Process On Workflow Event
The `onWorkflowEvent` method is used to attach an event handler to the 'workflow-event' event of the Job.
const result = await myProcess.start().onWorkflowEvent(e => console.log(e.name));
### Stop Process
The `stopProcess` method is used to stop an executing robot process.
It returns a promise which is resolved on successful cancellation of the running robot process.
const result = await myProcess.start();
await robot.stopProcess(myProcess);
## Model Definitions
### IRobotSDK
interface IRobotSDK {
    settings: Settings;
    getProcesses(): Promise<Array<RobotProcess>>;
    init(): IRobotSDK;
    on(eventName: string, callback: (argument?: any) => void): void;
    startJob(job: Job): Promise<JobResult>;
    stopProcess(process: RobotProcess): Promise<void>;
    installProcess(processId: string): Promise<InstallProcessResult>;
### Settings
class Settings {
    portNumber: number;
    pollTimeInterval: number;
    disableTelemetry: boolean;
### RobotProcess
class RobotProcess {
    description?: string;
    start: (inArguments?: any) => JobPromise;
    install: () => Promise<InstallProcessResult>;
### InstallProcessResult
class InstallProcessResult {
    inputArgumentsSchema: InputArgumentSchema[]
### InputArgumentSchema
class InputArgumentSchema {
    type: string;
    isRequired: boolean;
    hasDefault: boolean;
### JobPromise
class JobPromise {
    onStatus(eventHanlder: (argument?: any) => void): JobPromise;
    onWorkflowEvent(eventHanlder: (argument?: any) => void): JobPromise;
### Job
class Job {
    processId: string;
    argument?: any;
    jobId: string;
    on(eventName: string, eventHanlder: (argument?: any) => void): void;
### JobResult
class JobResult {
    [Key: string]: any;
### WorkflowEventData
class WorkflowEventData {
    payload: string;
