# Connection troubleshooting
> The tenant you are trying to access does not have authentication enabled.
## Interactive sign-in is not enabled for this tenant
### Description
### Potential issue
The tenant might have been created in an older version of Orchestrator, prior to the implementation of the interactive sign-in feature.
### Solution
The proposed solution must be performed by an Orchestrator administrator:
* In Orchestrator, go to **Tenant** &gt; **Settings** &gt; **Security** , and then select **Allow both user authentication and robot key authentication**.
To connect using your machine key instead, go to the sign-in screen in Studio, then select **More Options** &gt; **Connect to Orchestrator**.
## Interactive connect is not available
### Description
You cannot connect through the Interactive Sign-In.
### Potential issue
The Robot is installed in Service Mode.
### Solution
When the Robot is installed in Service Mode, connect using the **Machine Key** first, then proceed with Interactive Sign-In (Service URL).
## Robot does not exist
### Description
You receive the error message "Robot does not exist".
### Potential issue
You might be using a classic robot, which was defined in Orchestrator using the classic method or via the Windows user, and you are already connected to Orchestrator with a machine key. When you then sign in from Studio, a different username is sent to Orchestrator.
### Solution
* In Orchestrator, set up a modern robot, then sign in again.
## Cannot acquire a license
### Description
You receive the error message "Cannot acquire a license".
### Potential issue
Your user account is not properly configured to acquire a license from Orchestrator.
### Solution
* In Orchestrator, edit the problematic user account to execute attended automations, then assign it an Attended license.
To verify the license availability, go to **Tenant** &gt; **License**.
## No such host in known
### Description
You receive the error message "No such host in known".
### Potential issue
Connection to Orchestrator could not be established.
### Solution
Make sure your Internet connection is working.
## You are not authorized to perform this action
### Description
You receive the error message "You are not authorized to perform this action".
### Potential issue
The user connected with the machine key associated with one tenant, but then tries to sign in to a different tenant.
### Solution
For User Mode installations, sign in using the service URL.
For Service Mode installation, sign out from the Assistant, then sign in again.
## Could not start executor in an RDP setup
### Description
You receive the error message "Could not start executor. RDP connection failed: Message: The connection transport layer failed. Last error: 131085".
### Potential issue
The user account used to run the unattended automation runs was not added to the **Remote Desktop Users** group.
### Solution
Add the user account to the **Remote Desktop Users** group. For details, see [User permissions to run automations](https://docs.uipath.com/robot/standalone/2024.10/admin-guide/prerequisites-unattended-installation).
## Robot cannot connect to an Automation Suite Orchestrator instance
### Description
When trying to connect or sign in to an Orchestrator provided with Automation Suite 2024.10, you may encounter this error: "System.Net.Http.HttpRequestException: The SSL connection could not be established, see inner exception."
This issue affects Windows 10 and Mac operating systems.
### Potential issue
Automation Suite 2024.10, which hosts the Orchestrator instance you want to connect to, [uses TLS 1.3 by default](https://docs.uipath.com/automation-suite/automation-suite/2024.10/release-notes/automation-suite-2024-10-0#support-for-tls-13). Windows 10 and Mac operating systems do not support this version.
### Solution
You have two options:
* [Configure Automation Suite 2024.10 to use TLS 1.2](https://docs.uipath.com/automation-suite/automation-suite/2024.10/installation-guide/how-to-address-weak-ciphers-in-tls-12) instead, or
* Use an operating system other than Windows 10 or Mac.
